Nested Block Data Extraction
attila_nagyNMWRC
attila_nagyNMWRC
Community Visitor
Community Visitor
Hello!
I have nested blocks, with flip and visibility states.
The attributes and data needs to be extracted via code, here we use ezdxf, which is a Python library.
Unfortunately we are not bale to extract the block level, the flip and the visibility state.
It just lists this:
LAYERS:
0
LX CS Retroreflective Sensor
LX CS Diffuse Sensor
Defpoints
BLOCKS AND LETTERS:
Block: *Model_Space
Block: *Paper_Space
Block: *Paper_Space0
Block: Sensor
Attribute: ITEMCODE = 000250
Attribute: ITEMCODE = 000125
Block: *U2
Block: LX CS Diffuse Sensor
Block: LX CS Retroreflective Sensor
Block: *U5
Attribute: ITEMCODE = 123456
Block: *U6
Block: *U7
Block: *U8
Block: *U9
Block: *U10
Block: *U11
ENTITIES IN MODELSPACE:
Entity: INSERT
handle: 569
owner: 1F
layer: LX CS Retroreflective Sensor
insert: (250.0, 125.0, 0.0)
METADATA:
DWG Version: AC1032
DXF Units: 4
paullimapa
Sounds like you need to contact the ezdxf developers to resolve this or run AutoCADs Dataextraction command which LT doesn’t support
Paul Li
IT Specialist
@The Office
attila_nagyNMWRC
Community Visitor
Community Visitor
Dear Paul!
Thank you very much for your answer!
Yes, we already did contact them, but it would be nice to know, what we need to look for.
What are the official "Attributes" or the code within DXF for Nesting Level, Flip and Visibility State?
I know about Dataextraction, but we need to automatically make it via an online upload. What would our files look like with Dataextraction?
Best regards
Attila
paullimapa
With Dataextraction it can be a csv file which is like a text file
https://forums.autodesk.com/t5/dynamic-blocks-forum/data-extraction-based-on-shown-visibility-state/...
If you’re running LT 2024 there might be lisp routines that may also fit your needs
https://www.theswamp.org/index.php?topic=32825.0
Paul Li
IT Specialist
@The Office
