Data extraction based on shown visibility state
nikm42Q9N
nikm42Q9N
Attached is a block with three visibility states (circle, square, triangle) I have copied the block three times so each shape is shown separately. I want to run a data extraction and get a count of each shape and how many times appears in the drawing.
So the desired output would be:
Circle 1
Square 1
Triangle 1
but what i get is
Block Name-Circle-Square-Triangle
The data extraction combines all the attrbutites in the block into one row when I need is seperate and counted in separate rows
Any help would be appreciated
chadwickt
Hey there! I think I was able to get this to work properly. I don't think I did anything special. I chose the block in the extraction wizard, chose Visibility1 for the extraction property, removed the name column and combined identical rows. I hope this helps...
chadwickt
I see what happened now. You had it report the attribute name. Instead, I had it report the name of the visiblity state. I don't think attributes work well when they are in separate visiblity states. Hopefully just using the Visiblity1 parameter will work for you!
