Need to add text size option to this LISP
Mabwys
Observer Observer
Mabwys
Observer
Observer
Hello! I am new to coding and I'm not sure how to add a line about text size. I was able to change the size of the octagon, but I need the text size to update with it. Any solutions? LISP file is attached
calderg1000
Regards @Mabwys
Maybe this change will help.
; inserts increasing numbers inside hexagon
(defun c:nmp (/ p n ni ts oecho ds th txt na)
;;;  (if (= 0 (getvar "dimscale"))
;;;;;;    (setq ds 1.0)
;;;;;;    (setq ds (getvar "dimscale"))
;;;  (setq th (getvar "dimtxt"))
  (setq th(getreal"\nEnter text height...:"))
;;;  (setq txt (* th ds))
  (setq txt th)
  (setq ts txt)
  (if nn (setq nn (fix nn))(setq nn 1))
  (if (= nn 0)(setq nn 1))
  (princ "\n Increment by < ")
  (princ nn)
  (princ " >? : ")
  (setq ni (getint))
  (if (= ni nil)(setq ni nn)(setq nn ni))
  (if np
    (setq np 1)
  (princ "\n Start or continue with number < ")
  (princ np)
  (princ " >? : ")
  (setq n (getint))
  (if (= n nil)
    (setq n np)
    (setq np n)
  (setq p (getpoint "\n Number location: "))
  (setq oecho (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (while p
    (setq na (itoa n))
    (entmake (list (cons 0 "TEXT")
		    (cons 10 p)
		    (cons 11 p)
		    (cons 1 na); actual text
		    (cons 7 (getvar "TEXTSTYLE"))
		    (cons 40 txt)
		    (cons 72 4)
    (if (> n 99)
      (command "polygon" "8" p "c" (* ts 142.5))
      (command "polygon" "8" p "c" (* ts 120)))
    (setq p (getpoint "\n Next number location: ")
	  n (+ ni n)
	  np n
  (setvar "cmdecho" oecho)
  (princ)
(princ "\n Type > NMP <  to insert numbers inside hexagon")
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Sea-Haven
Something similar. Square or Circle. Save the Multi lisps in a support path for autoload.
I seem to remember doing a slot with round ends. I am trying to remember wether mtext has other than a rectang as a background mask.
Mabwys
Observer
Observer
Hey this did help the text size, but it broke the rest of the code. I am using LT if that makes a difference
@calderg1000
nvm I fixed it thank you so much!!!!
