Loop blocks, search and match attribute value and change another value.
andreas7ZYXQ
andreas7ZYXQ
Im, trying to solve an easy problem for someone with more knowledge than me but for me a big one.
I have multiple blocks/dynamic blocks inside a drawing and i would like to see if it cointain a attribute with specific name and value and then if it exists update another one.
I would be more than happy if someone could finish and help me with this code. and i would be even more grateful if comments in the code.
So.
Loop all blocks
Has attribute SEKTION with value sek_num
Then:
Change attribute SEK_SIDA to sek_page
This i what i got so far and finding some code from lee mac.
(defun C:adress_se_blad (/ ss i ename)
(setq sek_num (getstring "Search for section number:"))
(setq sek_page (getstring "In wich page?"))
(while
 (not(eq "SEQEND"(cdr(assoc 0(entget(setq bEnt(entnext bEnt)))))))
 (if (eq "SEKTION" (cdr (assoc 2 (entget bEnt))));Has attribute name
   (entupd
     (cdr
       (assoc -1
         (entmod(subst(cons 1 "Lee Mac") (assoc 1 (entget bEnt)) (entget bEnt)
);end
Sea-Haven
For me use selection set, using "INSERT" filter, with block has atrributes, You can use VL get-attributes, then a simple loop to check is Tagname = SEK_SIDA and so on.
Post a sample dwg with a before and after after. Say at least 4 blocks.
andreas7ZYXQ
Lee Mac solved my problem, found a script and manage to change it so it works for me.
(defun c:adress_se_blad ( / des ent enx flg fnd idx new sel tag )
   (setq tag "SEK_SIDA"
   (if (setq sel (ssget "_X" (list '(0 . "INSERT") '(66 . 1))))
       (progn
           (setq fnd (strcase (getstring t "\nSpecify attribute value to find: "))
                 new (cons  1 (getstring t (strcat "\nSpecify new value for \"" tag "\" attribute: ")))
           (repeat (setq idx (sslength sel))
               (setq ent (entnext (ssname sel (setq idx (1- idx))))
                     enx (entget ent)
                     des nil
                     flg nil
               (while (= "ATTRIB" (cdr (assoc 0 enx)))
                   (cond
                       (   (= tag (strcase (cdr (assoc 2 enx))))
                           (setq des enx)
                       (   (or flg (setq flg (wcmatch (strcase (cdr (assoc 1 enx))) fnd))))
                   (setq ent (entnext ent)
                         enx (entget  ent)
               (if (and des flg)
                   (if (entmod (subst new (assoc 1 des) des))
                       (entupd (cdr (assoc -1 des)))
       (princ (strcat "\nNo blocks found in the active drawing."))
   (princ)
