Need Lisp to draw the grid and coordinates of the map sheet
Oliver_C3D
Message 1 of 22
Oliver_C3D
Hello Dears
I need a lisp grid and draw the coordinates of the map sheet in the image format below.
Thank you for your attention
Replies (21)
Message 2 of 22
Sea-Haven
I may have what you want but it works in layouts only, handles twisted ucs etc Co-ordinates are world.
Message 3 of 22
CADaSchtroumpf
See this thread, if this can respond...
Lisp coordinate grid - from viewport
Message 4 of 22
Oliver_C3D
Hello @Sea-Haven
Yes, I want to work on a model
That is, by running Lisp, it grids and coordinates
Message 5 of 22
Oliver_C3D
Hello @CADaSchtroumpf
Unfortunately it did not work
Message 6 of 22
CADaSchtroumpf
I have also an another version: it's work's only in Model Space
The code use (grread) don't forget to move your cursor for see the dynamic bounding box
You have to be familiar with the options.
Press the option key only, do not enter !!!
Message 7 of 22
Oliver_C3D
By what order is it executed?
I wanted in Model space
Message 8 of 22
CADaSchtroumpf
In fact the DIM-GRID command is more intended for use in object space.
But the application is not locked, you can make a grid in the paper space (it is enough to be in this space before launching the command) but I do not recommend this use.
The grid will always be that of the general system of the space used.
It remains to be tested to become familiar with the part of setting up in dynamic assistance mode of the grid
Message 9 of 22
Oliver_C3D
I hope you are fine
I'm sorry, I think you misunderstood me.
I want to grid and coordinate in the model space like the image below.
In fact, after clicking on the model space, take the scale from us and then draw the grid and coordinates according to the size of the map Kadr.
Message 10 of 22
Oliver_C3D
Hello
@CADaSchtroumpf
@Sea-Haven
My problem is still not solved unfortunately!
Message 11 of 22
CADaSchtroumpf
I cannot suggest another development.
I am attaching a video showing the process.
In the video we do not see the pressing of the keys that I do (respectively 'P' for the position of the frame, 'R' for the rotation of the frame and '-' to decrease the scale compared to that proposed by fault)
Will the video enlighten you on the manipulation to be carried out...?
Message 12 of 22
Sea-Haven
Very nice grid answer my $0.05 for paperspace matches a twisted viewport.
Message 13 of 22
Oliver_C3D
Hi @Sea-Haven
thank you
I wanted like this lisp in the model space and that it only coordinates on the left and top side.
Message 14 of 22
Sea-Haven
Keep searching for grid.lsp you should be able to find 1 that is close and the 2 extra side of text could be removed, I know with mine do a left and right twice for hor and ver. Ie 4 sides.
Message 15 of 22
grabiel_peru96
Friend, could you share your grid lips?
Thanks in advance
Message 16 of 22
Sea-Haven
Try this.
Message 17 of 22
grabiel_peru96
Excellent, thank you very much
Message 18 of 22
gxz1135261742
Observer
Observer
Excellent lisp for grid. I have one question: how could I reverse the direction of Easting by lisp as shown on the second photos?
Message 19 of 22
Sea-Haven
You would have to change the orientation of the text, I remember took a bit of working out. Using the text insertion point resetting Lower left upper right etc. It is in the code. It may be just swap Lr & Lor for the E's and change (setq ang (+ ang pi))
Message 20 of 22
gxz1135261742
Observer
Observer
Thank you very much!!!
