Need help working out something in a lisp routine.
q_Q25S5
q_Q25S5
Hi, i currently have a problem where i have a csv file with 2 locations (start and end point).
What i need is a quick lisp fix to draw a line between these 2 points, and for it to place a specific block on point A and B.
I also have attached a test file for the CSV and DWG
Thanks for your help in advance!
  • Lisp
Moshe-A
@q_Q25S5  hi,
it would more easy\simple if the csv file format would have each piece of data in seperate coulmn
pt name |   X    |  Y   |  Z  | other data (like start\end)
is this possible?
Moshe
q_Q25S5
@Moshe-A This will be a bit difficult since this is the setup we work with a lot..
i did try to simplify the file a little.
Moshe-A
formating the file is for your own good.
if you search this forum you will find alot of examples how to read from csv file (which is simple text file)
and draw lines\plines or insert some blocks from it.
Moshe
Moshe-A
here is one from great LEE MAC
CADaSchtroumpf
Quick and dirty with your DWG and CSV
To be adapted if necessary...
(defun c:readCSV ( / )
  (setvar "ATTDIA" 0)
  (setvar "ATTREQ" 0)
  (setvar "CMDECHO" 0)
  (setq
    input (getfiled "Select a CSV file" "" "csv" 2)
    f_open (open input "r")
  (setq l_read (read-line f_open))
  (while (setq l_read (read-line f_open))
    (setq txt1 (substr l_read 1 (vl-string-position 59 l_read)))
    (setq l_read (substr l_read (+ 2 (vl-string-position 59 l_read))))
    (setq x1_data (atof (substr l_read 1 (vl-string-position 59 l_read))))
    (setq y1_data (atof (substr l_read 1 (vl-string-position 59 l_read))))
    (setq txt2 (substr l_read 1 (vl-string-position 59 l_read)))
    (setq x2_data (atof (substr l_read 1 (vl-string-position 59 l_read))))
    (setq y2_data (atof (substr l_read 1 (vl-string-position 59 l_read))))
    (setq dist (atof (substr l_read 1 (vl-string-position 59 l_read))))
    (setq nam_blk (substr l_read 1 (vl-string-position 59 l_read)))
    (setq new_pt1 (list x1_data y1_data))
    (setq new_pt2 (list x2_data y2_data))
    (if (eq nam_blk "Startpunt") (setq nam_blk "well"))
    (command "_.layer" "_set" "B-WE-RI-DWA_RIOOLPUT_INSPECTIEPUT-S" "")
    (if (eq nam_blk "leak")
      (command "_.-insert" nam_blk "_none" new_pt1 1.0 0.0 "_.-insert" nam_blk "_none" new_pt2 1.0 0.0 )
      (command "_.-insert" nam_blk "_none" new_pt1 1.0 1.0 0.0 "_.-insert" nam_blk "_none" new_pt2 1.0 1.0 0.0)
    (command "_.line" "_none" new_pt1 "_none" new_pt2 "")
    (command "_.layer" "_set" "04-PUT-PUTNUMMER" "")
    (command "_.text" "_none" new_pt1 0.0 txt1)
    (command "_.text" "_none" new_pt2 0.0 txt2)
  (close f_open)
  (setvar "ATTDIA" 1)
  (setvar "ATTREQ" 1)
  (setvar "CMDECHO" 1)
  (prin1)
q_Q25S5
Thank you! This worked perfectly.
