Need help with Lisp to insert mutilple attribute Block in center of object and link field in block to object
quocanh_elnino
quocanh_elnino
Like the attach image, i have a attribute block with two field in block, can you help me code a lisp to:
- Insert block attribute to center of mutiple object (in one time)
- Relink feilds in new block ATT to object
Thanks for any help guys !
komondormrex
hey there,
check the following code
(defun c:block_label_pline (/ pline_sset pline_object llc urc label_block block_attribute_list)
	(if (setq pline_sset (ssget '((0 . "lwpolyline"))))
		(foreach pline_object (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex pline_sset))))
			(vla-getboundingbox pline_object 'llc 'urc)
			(setq llc (vlax-safearray->list llc)
				  urc (vlax-safearray->list urc)
				  label_block (vla-insertblock (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
											   (vlax-3d-point (mapcar '+ llc (mapcar '* '(0.5 0.5) (mapcar '- urc llc))))
											   "bkl qa1"
											   0.25 0.25 0.25 0
				  block_attribute_list (vlax-invoke label_block 'getattributes)
			(vla-put-textstring (nth 2 block_attribute_list) (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-objectid pline_object)) ">%).TrueColor>%"))
			(vla-put-textstring (nth 3 block_attribute_list) (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-objectid pline_object)) ">%).Length \\f \"%lu2%pr2\">%"))
			(vla-put-layer label_block (vla-get-layer pline_object))
	(vla-regen (vla-get-activedocument (vlax-get-acad-object)) acactiveviewport)
	(princ)
quocanh_elnino
@komondormrex Thanks you for help ! It work very well 🤗
