LISP to extract and display as a note Z-elevation of a 3D snap points
alex7003
alex7003
Hi guys,
I have generated 3D path of a complex drain system.  Is any existing lisp routine to pick, extract and notate in XY plane Z-coordinates of a points of interest, similar to surveying points?
Thank you,
Alex
paullimapa
alex7003
Paul, thanks for the tip! The link takes me to mapping forum with near 6000 threads, could you please send me the file or help finding it?
autoid374ceb4990
Here is a very simple LSP routine that I wrote many years ago.
It will label the elevation of a picked point using the current TEXTSIZE variable.
(defun C:label_elev( / s p1 x y z)
(setq tsize (getvar "TEXTSIZE"))
(if (= prec nil) (setq prec 2))
(setq prmpt (strcat "\nCoordinate Precision <" (itoa prec) ">:"))
(setq s (getint prmpt))
(if (/= s nil) (setq prec s))
(while 1
(setq p1 (getpoint "\nSelect Point : "))
(setq z (caddr p1))
(setq s (rtos z 2 prec))
(setq p1 (getpoint "\nLocation : "))
(command "_.TEXT" p1 tsize 0.0 s)
paullimapa
Unfortunately Autodesk has since archived the older threads so that link is no longer valid.
Paul Li
IT Specialist
@The Office
Sea-Haven
If its a 3dPline then this will make a list of all the points.
(defun co-ords2xy (xyz co-ords / I XY )
(setq co-ordsxy '())
(if (= xyz 2)
  (progn
    (setq I 0)
    (repeat (/ (length co-ords) 2)
    (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
    (setq co-ordsxy (cons xy co-ordsxy))
    (setq I (+ I 2))
(if (= xyz 3)
  (progn
    (setq I 0)
    (repeat (/ (length co-ords) 3)
    (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) ))
    (setq I (+ I 3))
(princ)
(defun c:getxyz ( / obj entname)
(setq obj (vlax-ename->vla-object (car (entsel "\nPlease choose 2d or 3d pline "))))
(setq entname (vlax-get obj 'objectname))
(if (= entname "AcDb3dPolyline")
  (setq 23d 3)
  (setq 23d 2)
(setq coords (vlax-get obj 'coordinates))
(co-ords2xy 23d coords)
(princ)
From this can add draw text.
