Need help with Lee Mac Lisp "Col2Back"
jk1173
jk1173
This lisp sends objects to back that are set to a certain color.  It has been working but now has mysteriously stopped and now gives the error "AutoCAD.Application: Invalid input".  This code is way more advanced than my understanding so any help is appreciated.
Jared
;; Colour(s) to Back  -  Lee Mac
;; Sends all objects of specific colour(s) (object colour/layer colour) to the back of the draw order.
(defun c:col2back ( / *error* blk bll col doc exd lac lck ls1 ls2 sor )
    (setq col '(9 13 14 21 51 61)) ;; List of colour(s) to send to back
    (vlax-for lay (vla-get-layers (setq doc (vla-get-activedocument (vlax-get-acad-object))))
        (if (= :vlax-true (vla-get-lock lay))
            (vla-put-lock (car (setq lck (cons lay lck))) :vlax-false)
        (if (member (vla-get-color lay) col)
            (setq lac (cons (vla-get-name lay) lac))
    (vlax-for blk (vla-get-blocks doc)
        (if (and (= :vlax-false (vla-get-isxref blk)) (= :vlax-false (vla-get-islayout blk)))
            (   (lambda ( / lst )
                    (vlax-for obj blk
                        (if (or (and (= acbylayer (vla-get-color obj)) (member (vla-get-layer obj) lac))
                                (member (vla-get-color obj) col)
                            (setq lst (cons obj lst))
                    (if lst
                        (progn
                            (setq exd (vla-getextensiondictionary blk)
                                  bll (cons (vla-get-name blk) bll)
                            (vlax-invoke
                                (cond
                                    (   (LM:catchapply 'vla-getobject (list exd "acad_sortents")))
                                    (   (vla-addobject exd "acad_sortents" "acdbsortentstable"))
                                'movetobottom lst
    (vlax-for lay (vla-get-layouts doc)
        (vlax-for obj (setq blk (vla-get-block lay))
            (cond
                (   (or (and (= acbylayer (vla-get-color obj)) (member (vla-get-layer obj) lac))
                    (setq ls1 (cons obj ls1))
                (   (and (= "AcDbBlockReference" (vla-get-objectname obj)) (member (vla-get-name obj) bll))
                    (setq ls2 (cons obj ls2))
        (if (or ls1 ls2)
            (progn
                      sor
                    (cond
                (if ls2 (vlax-invoke sor 'movetobottom ls2))
                (if ls1 (vlax-invoke sor 'movetobottom ls1))
    (foreach lay lck (vla-put-lock lay :vlax-true))
    (vla-regen doc acallviewports)
    (princ)
;; Catch Apply  -  Lee Mac
;; Applies a function to a list of parameters and catches any exceptions.
(defun LM:catchapply ( fun arg / rtn )
    (if (not (vl-catch-all-error-p (setq rtn (vl-catch-all-apply fun arg)))) rtn)
(vl-load-com) (princ)
Jared - Sr. CAD Technician
Words to live by: If it ain't broke, you're not trying hard enough.
e3do
Lee is top notch at writing these. I've encountered errors occasionally while using his (and other) routines.
If it just stopped working:
Normally I'll just restart AutoCAD and everything's fine. Hopefully this is one of those times (when you're like, "really"?)
jk1173
After looking more closely, it is actually working, but is still throwing up the error.  I guess as long as it is working, I won't worry about the error.
