- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
Have a question about the best way to modify this code to automatically know how many pages are in a pdf and size them appropriately within the paper space page layout. The code currently ask in its second step how many pages the user wants to bring in from the selected pdf. I want to bypass that 2nd step and have the code be able to know how many pages are in the pdf document and automatically place them and scale them on the page.
I want to size the pdf pages/documents as follows:
- If the file has 1 sheet and is in portrait orientation, then the insertion location should be "4.5, 1.375" and scale of "0.75".
- If the file has 1 sheet and is in landscape orientation, then the insertion location should be "0.75, 1.375" and be a scale of "0.75".
- If the file has 2 sheets, then the insertion locations should be "0.75, 1.375" for the 1st page and "7.5, 1.375" for the 2nd page, both with a scale of "0.75".
- If the file has 3 sheets, then the insertion locations should be "0.75, 3.025" for the 1st page, "5.23, 3.025" for the 2nd page, and "9.71, 3.025" for the 3rd page, all with a scale of "0.48".
- If the file has 4 sheets, then the insertion locations should be "0.37629, 3.3" for the 1st page, "3.85812, 3.3" for the 2nd page, "7.33995, 3.3" for the 3rd page, and "10.8218, 3.3" for the 4th page.
BUPSUP(defun c:BUPSUP ( / )
(c:BUPSUP)
(defun c:BUPSUP
; Functions
MN:ListBox _PDFPageCount findEmptySlot IncrementSheet ClearSheet
;Variables
dir lst mfr specs inspts pt scl pages page_lst cur_layout
(cb:writetotext "networks" "SPCI")
(vl-load-com)
(defun MN:ListBox ( title lst bit / *error* dch des tmp res )
(defun *error* ( msg )
(if (< 0 dch)
(unload_dialog dch)
(if (= 'file (type des))
(close des)
(if (and (= 'str (type tmp)) (setq tmp (findfile tmp)))
(vl-file-delete tmp)
(if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
(princ (strcat "\nError: " msg))
(princ)
(cond
(not
(and
(setq tmp (vl-filename-mktemp nil nil ".dcl"))
(setq des (open tmp "w"))
(write-line
(strcat
"listbox : dialog
label = \"" title "\";
spacer;
: list_box
key = \"list\";
multiple_select = " (if (null bit) "false" "true")";
width = 50;
fixed_width = true;
spacer;
ok_cancel;
des
(not (close des))
(< 0 (setq dch (load_dialog tmp)))
(new_dialog "listbox" dch)
(prompt "\nError loading list box.")
( 1
(start_list "list")
(foreach item lst (add_list item))
(end_list)
(setq res (set_tile "list" "0"))
(action_tile "list" "(setq res $value)")
(setq res
(if (= 1 (start_dialog))
(mapcar '(lambda ( x ) (nth x lst)) (read (strcat "(" res ")")))
(if (< 0 dch)
(setq dch (unload_dialog dch))
(if (not (null res))
res
nil
(defun _PDFPageCount ( filename / fob fso mat reg res str )
(if
(and
(setq filename (findfile filename))
(eq ".PDF" (strcase (vl-filename-extension filename)))
(vl-catch-all-apply
(function
(lambda ( / _ReadAsTextFile _CountPage )
(defun _ReadAsTextFile ( fso fn / fob str res )
(setq
fob (vlax-invoke fso 'getfile fn)
str (vlax-invoke fso 'opentextfile fn 1 0)
res (vlax-invoke str 'read (vlax-get fob 'size))
(vlax-invoke str 'close)
(vlax-release-object str)
(vlax-release-object fob)
res
(defun _CountPage ( rgx str / mat pag )
(vlax-put-property rgx 'pattern "/Type\\s*/Page[^s]")
(vlax-put-property rgx 'ignorecase actrue)
(vlax-put-property rgx 'global actrue)
(setq
mat (vlax-invoke rgx 'execute str)
pag (vlax-get mat 'count)
(vlax-release-object mat)
(if (zerop pag) 1 pag)
(setq
fso (vlax-create-object "Scripting.FileSystemObject")
reg (vlax-create-object "VBScript.RegExp")
str (_ReadAsTextFile fso filename)
res (_CountPage reg str)
(foreach obj (list str fob mat fso reg)
(vl-catch-all-apply 'vlax-release-object (list obj))
res
;; Translation by Lee Mac of the VBScript code by Chanh Ong
;; found at http://docs.ongetc.com/?q=content/pdf-pages-counting-using-vb-script
;; Call with fully qualified filename of PDF file:
;; (_PDFPageCount "C:\\Folder\\Filename.pdf")
;; Returns integer describing number of pages in specified PDF file
(defun findEmptySlot ( lst / i ent nums )
;; CONVERT LST "1.009,2.869,3.14" -> (LIST 1.009 2.869 3.14)
(setq i 0)
(cond
((eq 'STR (type (nth i lst)))
(setq nums (mapcar '(lambda (x y) (cons (atof (substr x 1 (vl-string-search "," x))) (atof (substr y (+ (vl-string-search "," y) 2))))) lst lst))
(while (and (setq ent (nentselp "" (list (car (nth i nums)) (cdr (nth i nums))))) (/= i (1- (length lst))))
;(vl-remove-if-not '(lambda (x) (wcmatch x "*R-*")) (layoutlist))
(setq i (1+ i))
(if (null ent)
(nth i lst)
(defun ClearSheet ( ss / ind ent )
(repeat (setq ind (sslength ss))
(setq
ind (1- ind)
ent (ssname ss ind)
(entdel ent)
(princ)
; [SS] SELECTION SET
; CLEARS OUT ALL ENTITIES PASSED AS SELECTION SET [SS]
(defun IncrementSheet ( sht / sht+ )
(setq sht+
(strcat
(substr sht 1 (1+ (vl-string-search "-" sht)))
(rtos (1+ (atoi (substr sht (+ (vl-string-search "-" sht) 2)))) 2 0)
;;; MAIN ;;;
(setq dir "C:\\_Vault\\ATC\\DAS\\_DAS Library\\BUP Supplementals")
(if (not (vl-file-directory-p dir))
(princ (strcat "Directory: " dir "\nNot found.\nPlease download/'GET' this location from Vault."))
(progn
(setq lst (vl-remove-if '(lambda (x) (and (member x (list "." ".." "_V")))) (vl-directory-files dir nil -1)))
(if
(and
(setq mfr (car (MN:ListBox "Select Generator Manufacturer:" lst nil)))
(setq specs (MN:ListBox "Select Generator Spec Sheet(s):" (vl-directory-files (strcat dir "\\" mfr) "*.pdf*" 1) 1))
(progn
(setq
inspts (list
"0.60475,1.38142"
"7.42514,1.38142"
scl "0.77272727"
(if (vl-catch-all-error-p (vl-catch-all-apply 'setvar (list "CTAB" "R-601")))
(princ "\nError.\nLayout tab 'R-601' does not exist.")
(foreach spec specs
;(command-s "PDFATTACH" (strcat dir "\\" mfr "\\" spec))
(setq pages (_PDFPageCount (strcat dir "\\" mfr "\\" spec)))
(setq page_lst nil)
(repeat pages
(setq page_lst (cons (rtos pages 2 0) page_lst))
(setq pages (1- pages))
(setq page_lst (MN:Listbox (strcat "Select " spec " sheet(s):") page_lst 1))
(foreach p page_lst
(setq cur_layout (getvar "CTAB"))
(while
(not
(cond
((setq pt (findEmptySlot inspts))
; insertion point or nil
T
((vl-catch-all-error-p (vl-catch-all-apply 'setvar (list "CTAB" (setq cur_layout (IncrementSheet (getvar "CTAB"))))))
; T or nil
(command "_.LAYOUT" "C" (getvar "CTAB") cur_layout)
(setvar "CTAB" cur_layout)
(ClearSheet (ssget "C" '(0.60475 9.88142) '(13.9933 1.38142)))
(command "-PDFATTACH" (strcat dir "\\" mfr "\\" spec) p pt scl "0.0" nil)
(setq pt nil)
(princ "\nFunction canceled")
(princ)
I've attached the lisp code and the template to help with context. Feel free to modify the setq dir "C:\\_Vault\\ATC\\DAS\\_DAS Library\\BUP Supplementals" to any location with whatever pdfs you want to use to test out the code.
Appreciate any help.
