Hello to all:
Could someone please help me out with some example code... I need to use LISP to:
1) grab a dynamic block named "ExampleBlock" from "ExampleDwg" located at C:\New folder
2) Change the parameter in that block named "DistanceOne" from a previously-set value to 21
3) insert with mouse click in the current dwg
Thanks very much for any help. I have a large library of blocks organized by width. It would be VERY helpful if I only had to maintain ONE set of blocks. Right now, if a problem is discovered, I have to go back and modify at least seven different width-variants. If I could just have my users insert ONE block from a tool palette with a width that could be entered beforehand (I will work on that coding later) it would make my life SOOOO much easier. Thanks in advance!
