Need example of code for inserting a dynamic block and changing a param
acadadmin3KNUF
Message 1 of 10
acadadmin3KNUF
Hello to all:
Could someone please help me out with some example code...  I need to use LISP to:
1) grab a dynamic block named "ExampleBlock" from "ExampleDwg" located at C:\New folder
2) Change the parameter in that block named "DistanceOne" from a previously-set value to 21
3) insert with mouse click in the current dwg
Thanks very much for any help.  I have a large library of blocks organized by width.  It would be VERY helpful if I only had to maintain ONE set of blocks.  Right now, if a problem is discovered, I have to go back and modify at least seven different width-variants.  If I could just have my users insert ONE block from a tool palette with a width that could be entered beforehand (I will work on that coding later) it would make my life SOOOO much easier.  Thanks in advance!
Replies (9)
Message 2 of 10
Sea-Haven
As you want from palette can be done pretty easy, you need to have 1 lisp loaded either autoloaded or as part of the palette command.
(load "dynam blk.lsp")(dynam "xxx" prp value)
So the lisp has a defun dynam passing the block name which can be "C:\\New folder\\Exampledwg\\ExampleBlock" the "size"  would be a number. The prp is the block parameter name.
You also need Lee-mac Dynamic block lisp for the put value into a block.
;Thanks to Lee for dynamic block stuff
(defun LM:setdynpropvalue ( blk prp val )
If you get stuck post again.
Message 3 of 10
pbejse
All can be done thru Tool Palette
Create a copy on the tool palette per Custom values and the n you're good to go.
Message 4 of 10
ВeekeeCZ
See the example below.
Credit for all the hard work one this belongs to Lee Mac. I just did minor adjustments.
HTH
Message 5 of 10
acadadmin3KNUF
Hello:
Thanks very much for your contribution...but It is not functioning correctly yet.  I've attached an updated verson of your file, the dwg with the ExampleBlock, and a screenshot showing the block's name, the parameter's name, and the file location.  In your program, i tweaked the "if failure" line to spit out some text that says "no this didnt work yet" rather than just simply exiting.
I have spent the fast few hours constantly searching, and all I seem to find is "the user is prompted to select from a list..."
NO!  That's NOT what I want.  I don't want the user prompted to select ANYTHING except the block's insertion point and insertion rotation.  That's the whole point of this post, I want to define most of the parameters BEFOREHAND.
I understand perfectly how Lee Mac's "Set Dynamic Properties" works.  I have about 35 blocks that are on this tool palette,, so I need a button for each one that runs code which will populate SEVERAL of this kind of statement.  For example:
(LM:setdynpropvalue obj "BF" (15))
(LM:setdynpropvalue obj "SWITCH: CONTROLS SIDE" (LH CONTROLS))
In this example, the block would be inserted AUTOMATICALLY with "BF" set to "15" and "SWITCH: CONTROLS SIDE" set to "LH-CONTROLS", and the user would be asked for the insertion point and rotation ONLY.
I know this is possible.  I'm soooo close it's getting even more frustrating.  Thanks in advance for any continued help!
Message 6 of 10
ВeekeeCZ
Code updated. As usual, just minor inconsistency. Sorry about that.
Message 7 of 10
acadadmin3KNUF
Hello, thanks for the update message.  I'm not seeing any file attached to your updated reply, can you check again?  Thanks so much for your help! 😁
Message 8 of 10
pbejse
That means attached code at post #4 is updated @acadadmin3KNUF
This
(BLM:importblock path "block")
To
(BLM:importblock path block)
HTH
Message 9 of 10
acadadmin3KNUF
THERE we go! Fantastic, thanks! 😁
Message 10 of 10
pbejse
Glad it works for you, the credit goes to Z9E3zK5E at post #4
You are welcome nonetheless @acadadmin3KNUF  🙂
[ switched ]  All is right again 🙂
