Need a Lisp that can convert all MTEXT colors to required colors
Dear Experts,
I have MTEXT's with different colours in it. The lisp code should asks the user input for color and then to be applied for selected MTEXT's. Please refer to attached Drawing.
Kent1Cooper
There's a routine called STRIPMTEXT that you can Search for, which will take out internal formatting such as color overrides.  Then you can just select the objects and give them all the same color in the Properties palette.
Kent Cooper, AIA
Thank you for solutions Sir.
But it's just resetting the mtext internal values only.
If I want change MTEXT width factor for selected only, then there is no option to update the MTEXT internal width factor. Please help me in this.
