Need a lisp file to combine files and give it the name of the current drawing
Hans_Knol
Message 1 of 8
Hans_Knol
Hello all,
I'm looking for a lisp routine that can put the contents of 4 different files into one file and give the name of the file the name of the current drawing.
so the names of the exported files (from AutoCAD Electrical) are,
SheetData.tmp
WireToData.tmp
WireFromData.tmp
EquipmentData.tmp
All these file will be stored into the directory "C:\Data\AppData\ACAD\process", after generate the new file it must be saves in the same directory with the filename of the current drawing for example "Drawing1.txt"
Hopy somebody can help me with this.
Hans
Hans Knol
Replies (7)
Message 2 of 8
ronjonp
Sure:
(defun c:foo (/ _writefile _readfile A B D R)
  ;; RJP » 2020-01-10
  (defun _writefile (fn lst / file r)
    (cond ((and (eq 'str (type fn)) (setq file (open fn "w")))
	   (foreach x lst (write-line x file))
	   (close file)
	   fn
  (defun _readfile (fn / f r l)
    (cond ((and (eq 'str (type fn)) (setq fn (findfile fn)) (setq f (open fn "r")))
	   (while (setq l (read-line f)) (setq r (cons l r)))
	   (close f)
	   (reverse r)
  (setq d "C:\\Data\\AppData\\ACAD\\process\\")
  (foreach f '("EquipmentData.tmp" "WireFromData.tmp" "SheetData.tmp" "WireToData.tmp")
    (and (setq a (findfile (strcat d f))) (setq b (_readfile a)) (setq r (cons b r)))
  ;; Check that there are 4 entries to write
  (if (= (length r) 4)
    (_writefile
      (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) ".txt")
      (apply 'append r)
    (alert "All files not found!")
  (princ)
Message 3 of 8
hak_vz
(defun join_files ( / path filelist f joined)
    (setq
        path
        filelist
            (list
                (strcat path "\\" "SheetData.tmp")
                (strcat path "\\" "WireToData.tmp")
                (strcat path "\\" "WireFromData.tmp")
                (strcat path "\\" "EquipmentData.tmp")
        f
            (strcat path "\\" "Drawing1.txt")
        joined
            (fopen f "W")
    (foreach g filelist
        (cond ((findfile g)
            (setq file (open g "r"))
            (while (setq line (read-line file))(write-line line joined))
            (write-line  " " joined)
            (close file)
    (close joined)
    (princ)
Miljenko Hatlak
Message 4 of 8
Sea-Haven
Very very easy using old fashioned DOS the copy command supports joining files to a new file. So for your request the DOS command is
copy SheetData.tmp+WireToData.tmp+WireFromData.tmp+EquipmentData.tmp dwgfilename.tmp
You just use strcat to make the correct string as above then use the "shell" command
(command "shell" copystr)
Using prior code there should be enough info to work it out.
Message 5 of 8
Sea-Haven
Found a few minutes. need to replace path etc and filenames.
If hit maximum characters due to paths just do file1+file2 -> tmp tmp+file3 etc till done.
(defun join_tmp ( / path filelist )
(setq dwgname (cadr (fnsplitl (getvar 'dwgname))))
    (setq path "D:\\Acadtemp")
    (setq  filelist
            (Strcat
                 "copy "
		 path "\\" "File1.txt+"
                 path "\\" "File2.txt+"
                 path "\\" "File3.tx+"
                 path "\\" "File4.txt" " "
				 path "\\" dwgname ".txt"
    (command "shell" filelist)
    (princ)
Message 6 of 8
hak_vz
Correction to take into account name of current dwg
    (setq
        path
        filelist
            (list
        f
            (strcat path "\\" (cadr (fnsplitl (getvar 'dwgname))) ".txt")
        joined
            (fopen f "W")
    (foreach g filelist
        (cond ((findfile g)
            (close file)
    (close joined)
    (princ)
Miljenko Hatlak
Message 7 of 8
devitg
Hi SeaHaven ,  as I can see the
fnsplitl
is a defun , similar to
vl-filename-base
Is it?
Message 8 of 8
Sea-Haven
Yes a pre VL version, can also do strip last 4 characters so remove .dwg
