cable tray lisp
cable tray lisp
jtm2020hyo
cable tray lisp
jtm2020hyo
I found a video where you can see the author creating a cable tray with their program, he shared the program in but looks like malware.
youtube link:
https://www.youtube.com/watch?v=DKiZPP0Qv14
blogspot link:
https://cad2all.blogspot.com/2018/11/draw-cable-tray-with-fittings-in.html
download link is inside the youtube video
their concept is very simple, convert a polyline to the cable tray.
anyone here already tested their program?
is there any complete lisp like this shared program for cable tray?
PD: the author use the same program in the same youtube channel for share one "menu bar" with multiple lisp.
_Tharwat
Kent1Cooper
I haven't looked at the videos, but a Search for "cable tray" here will bring up several routines, that work in various ways and give various kinds of results -- I did one that's >here<, and there are others [including on that thread alone].
Kent Cooper, AIA
jtm2020hyo
@_Tharwat wrote:
Here is my Cable Tray program?
https://autolispprograms.wordpress.com/cable-tray-program/
I did not find your code inside other programs ...
awesome program for cable tray but I found some think that might be solved:
1) I was testing your lisp but there does not exist a cross-shaped union.
2) only hatches vary between different types of cable trays. for "Ladder Cable Tray" should be inserted a line each every certain distance.
if that is solved, then your program might be perfect.
jtm2020hyo
attached the lisp that I found in your shared link.
I tested your lisp for cable tray, is an awesome lisp.
but I did not found unions like cross-shaped, t-shaped, u-shaped, L-shaped in 45 and 90 degrees (or any angle), and reducers.
I have a request, can you modify your lisp to convert polylines to cable trays? like the youtube video above
the size should be like the "global width"
_Tharwat
1) Yes I was also asked by a quite a few users to add cross-shaped union and Taper-Reducer and I am planning to
    add them as soon as possible.
2) Yeah different hatch means different types and add a center line for the ladder type is not a major task and can add it to the program along with the fore-said two blocks.
I believe it is perfect since I have hundreds of users over the world using it and they are paid users.
Thank you for taking the time to give your kind feedback about my program.
