- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello! first time poster here and really need some help. Im looking for a lisp command that will function like the Copy Array command in AutoCAD. the normal command is "Copy", select object, specify base point, then "Array", how many objects, then "Fit", then choose second point.
This command is useful when im putting joists in bays so I dont have to do the math for the spacing of the joists. However this command takes a looong time and its a one time command. I was wondering if there was a way to repeat the command.
I want to be able to start the command again from the second point but be able to change the quantity of objects im fitting in the next section. Can anyone point me to an existing lisps that does this, or if someone has the knowledge to be able to write it that would make me very happy!
I will drop a screen recording of the command im using and you can maybe see how I want the lisp to work.
Thank you!
