naming closed polylines and count
cizimcenter
Message 1 of 32
cizimcenter
I am working on curtainwall manufacturing drawing task in which I need to give unique number and need to make table with layer, width, length and count of each glass panel. Then i need to write names into each polylines center as a installation scheme.
But is it possible to add number with prefix and/or suffix (for example GL1-1,GL1-2,GL1-3) Automatically instead of just 1, 2, 3 ,4..... type number? A sample file is attached.
Can you please help with this?
Replies (31)
Message 21 of 32
Sea-Haven
@-didier- I suggested rotating the pline vertices so the start is always lower left and CCW so always get length and height from the the 3 vertices, no need for an area check, in saying this the sloping plines may need more thought. This may be helpful.
; thanks to dexus @ theswamp
(defun rotate-rectang (lst / corner)
  (setq corner ; find left most corner with a sort
    (car
      (vl-sort lst
        (function
          (lambda (a b)
            (if (equal (car a) (car b) 1e-4)
              (< (cadr a) (cadr b))
              (< (car a) (car b))
  (while (/= (car lst) corner) ; rotate until corner is the first item
    (setq lst (append (cdr lst) (list (car lst))))
  lst ; return lst
(rotate-rectang '((3240.0 1074.0) (3440.0 1074.0) (3440.0 1174.0) (3240.0 1174.0)))
 Do a CW or CCW check 1st.
Message 22 of 32
Brock_Olly
Didier,
This is a wonderful job, I'm sure many people could benefit from these commands!
I would also be interested in the LISP when you're done. Take your time.
Message 23 of 32
-didier-
Bonjour @cizimcenter
I am sorry for the slow response, but I promise you that I am looking for solutions.
The concern is that the days are only 24 hours and I take care of the grandchildren, work in the garden, at home, practice sports, and finally I come back to the PC
I changed my way to filter polylines, I work on the dimensions and this way it is more precise and unitary than the choice by area.
I still have to solve two/ three small problems because I want it to work in any case, and I will quickly deliver the program.
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 24 of 32
-didier-
The time has finally come!
This is the latest version that I think meets demand effectively.
I remain available for any adjustments or corrections if necessary.
Command names are : cizimcenter / creatable / legende
Amicalement
DA
Message 25 of 32
cizimcenter
Hi @-didier-
i have just tried and the commands work very well. You did it perfectly. Thanks a lot.
note: the text height in the table is very small but it is not problem. i can resize the table.
is it possible to round dimensions and merge GL-100 and GL-101? Because glass manufacturers do not work with precise measurements.
Message 26 of 32
Sea-Haven
@cizimcenter "the text height in the table is very small but it is not problem."
mine
(setq objtable (vla-addtable vgms sp numrows numcolumns rowheight colwidth))
other
  (setq table (vla-addtable
		(vla-get-modelspace *acdoc*)
		(vlax-3d-point ptable)
		(+ (length lt2) 2)
		5 420 1150 ))
  (vla-put-VertCellMargin table 4.0)
Look at the 420 compared to say the 4.0 the row height would be like 18 ? Try a few values. leave the 4.0 as is. You can also set textheight for a row.
Message 27 of 32
symoin
This is a wonderfull lisp code,  Can I request you to  to include the coordinates for the vertices of the polygons in the table?
Message 28 of 32
Sea-Haven
Just a quick question how do you want the co-ordinates shown X,Y or X Y X Y X Y X Y, 4 columns or 8 ? I am sure @-didier- will add once you answer.
Message 29 of 32
-didier-
Bonjour @symoin
Thank you for the compliments.
I never do anything in order to have a thank you or compliments but when they arrive I am happy to be part of the community.
For your coordinates details, it is possible (anything is possible) but I would need an example of the result to be obtained.
Draw a table “by hand” as you imagine it finished, and I will look at how to automate the task.
It will probably be wise to create a new message so as not to pollute this discussion with different requests.
Amicalement
DA
Message 30 of 32
symoin
It's great to see your response, and sorry for the delay. Here are the files.
Message 31 of 32
-didier-
Bonjour @symoin
OK, I have all what I need to write your program.
You understand that I am very busy, and then I can not promise a specific date of return.
Amicalement
DA
Message 32 of 32
symoin
Thanks a lot, No hurry, appreciate your efforts and time.
Thanks again
