naming closed polylines and count
cizimcenter
Message 1 of 32
cizimcenter
I am working on curtainwall manufacturing drawing task in which I need to give unique number and need to make table with layer, width, length and count of each glass panel. Then i need to write names into each polylines center as a installation scheme.
But is it possible to add number with prefix and/or suffix (for example GL1-1,GL1-2,GL1-3) Automatically instead of just 1, 2, 3 ,4..... type number? A sample file is attached.
Can you please help with this?
Replies (31)
Message 2 of 32
Brock_Olly
Hey! Looks like we have the same job 🙂
Do you already have a LISP to generate the table on the right, or did you fill that out manually?
Message 3 of 32
cizimcenter
i did it manually and takes too much time. that's why i need to automate.
Message 4 of 32
-didier-
Bonjour @cizimcenter
There are several possibilities to do this.
I’ll start with the simplest one.
Would you agree to use a dynamic block to make this kind of drawing?
If so, it will be possible to add attributes and extract them to a table.
If you do not agree with this method, I will think about something else.
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 5 of 32
cizimcenter
Bonjour @-didier-
clients usually send drawings as polylines. they convert 3d to 2d drawings from rhino or revit. if possible, i prefer a solution using poylines.
Message 6 of 32
-didier-
Of course! If you don’t say all this complicates the thing to help you.
How could I know that you are not the author of these polylines?
OK, I will think of something that starts from these polylines as starting hypothesis.
We stay in touch.
Amicalement
DA
Message 7 of 32
Sea-Haven
A couple of ideas you need to make a list of each rectang,  length & height & entityname, can then sort the list, then label the rectang, add the label to a new list. Do a count on the new list and draw a table.
Ok next option copy the rectangs to seperate objects do dims of the objects as seen on bottom of dwg.
Next step is send  to Excel ? Can do as part of make table or I have send a table to excel.
Thats a few steps, not a 5 minute job.
I dont know if you have seen this movie.
Added to my to do list it is getting bigger.
Have you considered getting a programmer on board ? There are many here who do customer work, yes you will need to pay. But you would provide a list of tasks including this one. Time savings can be immense a task manually around 3 hours now its 2 minutes.
Message 8 of 32
-didier-
Currently, I am at this solution, it is not finished, but I propose it before creating the table.
I take as reference the surface to associate the identical windows, therefore I do not draw in the same position the texts as your example, which is based on the starting point lower left.
Is it okay with you, or do I have to think again?
Amicalement
DA
Message 9 of 32
Sea-Haven
Code looks good @-didier- just a comment would the lower left panel be Gl-100 as a starting label not GL-101 ? I have a rotate pline vertices to lower left if you need it. Neede for another project. Can help in the sorting process.by lower left.
Attached send a Table to Excel your welcome to use it.
Message 10 of 32
baksconstructor
This AutoCAD add-on will solve your problem.
Here - MyPropertiesCAD
I remind the administrator - this is user assistance on the forum.
After which you can create a table of all objects.
After a while I will try to give a bigger example.
Message 11 of 32
cizimcenter
Hi @-didier-
it is OK. Names can be at the geometric centers of the polylines. naming from lower left is not compulsory. If would, it will be better.
Message 12 of 32
-didier-
I think good news should come soon.
I managed to increment from the bottom left.
I copied several times a few windows to check if the identical windows had the same label.
For me, it is OK, and You ?.
I will continue to process the table.
Amicalement
DA
Message 13 of 32
cizimcenter
Hi @-didier-
it works perfectly. That's what i need. thanks.
Message 14 of 32
mohammedhussain.noyadaKS7M4
Hello @cizimcenter,
I developed the command. Attaching the video for your reference.
Message 15 of 32
cizimcenter
@mohammedhussain.noyadaKS7M4
can you share the lisp file also?
Message 16 of 32
-didier-
I prefer to separate into different commands.
So the next one will be like this :
I work slowly because I do many other things at the same time.
When everything is effective, I will deliver the code.
Then we can make comparisons, because I’m glad to see that other members are interested in your question.
All ideas are good to take.
Amicalement
DA
Message 17 of 32
Sea-Haven
@mohammedhussain.noyadaKS7M4 you can set the width of the columns of a table, no need to pick and stretch. Same with start at settextheight for table.
(vla-setcolumnwidth objtable 0 17) ; column 0 width
Message 18 of 32
-didier-
As I said, I’m not quick to answer because I do several things.
This is my current version.
I rely on the end of the application, but I just realized that I have not treated well the lengths and widths. I will do it again.
I preferred to make three commands, it allows you to cut the phases. That’s my point of view.
If you prefer a single, complete action, it can be done without much effort.
By choosing to filter on surfaces to detect identical windows, I realize a limit, if two different windows have the same area
the program will create only one reference. I’ll work on that.
Amicalement
DA
Message 19 of 32
ec-cad
Suggest making a list of object / handle.
ECCAD
Message 20 of 32
cizimcenter
Hi @-didier-
the current version is OK. no problem, better late than never.
and three commands may be more useful.
best wishes
