Multiplication and Text Separation
k005
Advisor Advisor
Message 1 of 9
k005
Hi All !
2x62ø14/20 L=120
2x52ø14 L=120
2x82ø14/15/20 L=120
2x62ø14/9/14 L=120
We have data like text object
Question-1: Multiplying and updating the value in front of these articles.
Like 2x62 = 124ø14/20 L=120...
Question-2 : If this article is not two separate articles, separate them.
124ø14/20 L=120
Thanks in advance to the helper.
Replies (8)
Message 2 of 9
pbejse
(defun c:Anotherdemonstrationfork005 ( / selectionset increment entityData stringAssociationList
				      	stringFromstringAssociationList positionOf_Ø MultiplyThis Multiplied)
(if  (setq selectionset (ssget "_:L" '((0 . "TEXT")(1 . "*#x#*ø#*"))))
  	(repeat (setq increment (sslength selectionset))
		(setq entityData  (entget (ssname selectionset (setq increment (1- increment)))))
	  	(setq stringAssociationList (assoc 1 entityData))
	  	(setq stringFromstringAssociationList (cdr stringAssociationList))
	  	(and
		  (setq positionOf_Ø (vl-string-position 216 (strcase stringFromstringAssociationList)))
	  	  (setq MultiplyThis (substr stringFromstringAssociationList 1 positionOf_Ø))
		  (setq Multiplied (eval (read (strcat "( *  " (vl-string-translate "X" " " (strcase MultiplyThis)) ")"))))
		  (entmod
		    (subst
		      (cons
			1
			(strcat	(itoa Multiplied)
					(1+ positionOf_Ø)
		      entityData
  (princ)
Message 3 of 9
k005
Hello my friend,
Nice... well done. But question-2 is not included
Message 4 of 9
pbejse
@k005 wrote:
..But question-2 is not included
124ø14/20 L=120
You mean the string does not have a space " " between the number and "L=" or
Make it a separate Text object?
@k005 wrote:
Hello my friend, Nice... well done
Thank you for that @k005
But here's a question for you,  did you try to code it yourself? With all the help you're getting. I think you owe it to the community to at least try writing it.   Are you even interested to learn programming?
Message 5 of 9
k005
Make a separate Text object?
Yes . a separate text object. only L=xxx this part.
I know programming partially...
* Two posts on the same axis.. There may be two spaces between them, for example..
or how much space there is in the original...
Message 6 of 9
pbejse
If i give directions will you be able to put it together?
  • use Textbox  to identify the edge of the parsed string,
  • Entmake a new string on top of the original
  • Entmod the insertionpoint towards the edge + space
  • Change the string of the newly created Text object
Message 7 of 9
k005
No. I can't. Lisp seems too complicated to me. I know the main parts but that's all.
Thanks anyway mate.
Message 8 of 9
pbejse
(defun c:AndYEtAnotherdemonstrationfork005 ( / selectionset increment entityData stringAssociationList  stringFromstringAssociationList
				      	positionOf_Ø MultiplyThis Multiplied Newstring entityDataForNewString positionOf_L
				      	FirstString EdgeOfFirstString MoveDistance TextInsertionPoint)
	  	(and
		  (setq Newstring (strcat	(itoa Multiplied)
						(1+ positionOf_Ø)
		  (setq entityData (entmod (subst (cons 1 Newstring)  stringAssociationList entityData)))
		  (setq entityDataForNewString (mapcar '(lambda (p)(assoc p entityData )) '(0 10 7 40 41)))
		  (setq positionOf_L (vl-string-search " L=" Newstring))
		  ;(setq SizeOfTheTextObject (textbox entityData))
		  (setq FirstString (substr Newstring 1 positionOf_L))
		  (setq EdgeOfFirstString (textbox  (cons (cons 1 (strcat FirstString "X")) (Cddr entityDataForNewString))))
		  (Entmakex (append  entityDataForNewString (list (Cons 1  FirstString))))
		  (setq MoveDistance (+ (caar EdgeOfFirstString) (caadr EdgeOfFirstString)))
		  (setq TextInsertionPoint (cdr (cadr entityDataForNewString)))
		  (setq entityData (entmod (subst (Cons 10  (cons (+ (car TextInsertionPoint) MoveDistance) (Cdr TextInsertionPoint)))
				        		(cadr entityDataForNewString)	entityData)))
		  (entmod (subst (cons 1 (substr Newstring (+ 2 positionOf_L)))
				 (assoc 1  entityData) entityData))
  (princ)
Message 9 of 9
k005
Thank you very much, it's ok. 🤗
bless your hands.
