Connecting dynamic block with Autolisp or .net
abee123456789
Message 1 of 26
abee123456789
I am new to autolisp, and .net and looking for a little guidance in the right direction.
I have created two dynamic blocks a circle and a line. I have attached them.
I want to connect the circle block perpendicular to the line block.
and then split the line block where every the circle block connects to perpendicularly
I labeled them from step 1 being the beginning stage and step 3 being the final stage.
Any help will be appreciated.
Thank you,
Replies (25)
Message 2 of 26
Sea-Haven
A alternative approach may be easier than trying to do with dynamic blocks. There is various similar pattern joins out there.
Select circle blocks then line, a connect line is drawn and a question asked fillet yes no, would this be useful ?
Message 3 of 26
abee123456789
Not really, we used this blocks for all our drawings. I was just wonder if theres a macro or something that can do step 2 at least. Any ideas?
Message 4 of 26
Sea-Haven
Why not just make a new single dynamic block the correct shape ? You could have a dcl that asks for all the lengths etc. 3 vertical 3 horizontal and auto adjusts the block. Same with size 3/4. distance 1, distance 2 etc. Pretty sure You can link end of lines to a another end. I dont do much dynamic blocks some one may link yours. Can do front end then.
That would be my approach, how many patterns are involved ?
Message 5 of 26
abee123456789
Would that remove the dimensions?
Message 6 of 26
Sea-Haven
No, I dont do much with dynamic blocks but you should be able to link the objects using the stretch option. Hopefully some one will jump in redoing the block.
As I said earlier how many patterns?
Message 7 of 26
abee123456789
There many patterns. Is there way to use the grip of the circle block to meet the line block perpendicular to it
Message 8 of 26
Sea-Haven
What I was saying is rethink the whole pattern making. Enter a length draw line, add circle with a entered offset and size repeat as required, the offset is a simple -ve for left. This would be fast I use a dynamic dcl for this type of thing so it remembers the last entered values so may change only 1 value like length for repeated sides.
Ps use Donut for filled circle.
Message 9 of 26
pbejse
@abee123456789 wrote:
..I want to connect the circle block perpendicular to the line block.
I guess that can be done, tell us, is the attached drawing sample is just an example? or those blocks are the actual blocks you are going to use?
Writing a program that deals with Dynamic blocks will always have issues, especially with parameter names.
But this is certainly doable.
Also, please show more scenarios.
Message 10 of 26
abee123456789
The drawing is just an example. There could be 100 of circle blocks going different direction but I want to click a button or something that will be perpendicular to the line.
Message 11 of 26
pbejse
I figured as much.  The "line"  are of different angles not just Hor and Vert? if Yes show us please.
"Circle" block rotation is always 0? [ in relation to "Ängle1" parameter's value ]
Is there a direction for the "Line" block? This is important when placing these on the intersection point
The "Line" and "Circle"block is the actual block you're going to use YES?
Message 12 of 26
abee123456789
The circle block will be rotating in 90 degree increments
Message 13 of 26
ВeekeeCZ
Step 2 done.
(vl-load-com)
(defun c:Step2 ( / LM:setdynprops s p1 p2 a p x)
  ;; Set Dynamic Block Properties  -  Lee Mac ; http://www.lee-mac.com/dynamicblockfunctions.html#setdynamicprops
;; lst - [lst] Association list of (( . ) ... )
(defun LM:setdynprops ( blk lst / itm )
    (setq lst (mapcar '(lambda ( x ) (cons (strcase (car x)) (cdr x))) lst))
    (foreach x (vlax-invoke blk 'getdynamicblockproperties)
        (if (setq itm (assoc (strcase (vla-get-propertyname x)) lst))
            (vla-put-value x (vlax-make-variant (cdr itm) (vlax-variant-type (vla-get-value x)))))))
  (if (and (setq s (ssget "_:L" '((0 . "INSERT"))))
	   (setq p1 (getpoint "\nSpecify first point of vector: "))
	   (setq p2 (getpoint p1 "\nSpecify second point of vector: "))
	   (setq a (+ (/ pi 2) (angle p1 p2)))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i))))
      (setq p (cdr (assoc 10 (entget e))))
      (setq x (inters p1 p2 p (polar p a 1) nil))
      (LM:setdynprops (vlax-ename->vla-object e) (list (cons "Distance1" (distance p x))
						       (cons "Angle1" (angle p x))))))
  (princ)
Message 14 of 26
pbejse
@ВeekeeCZ wrote:
Step 2 done.
I also had step 2 at the ready @ВeekeeCZ 😉
I'm waiting on confirmation on other stuff like "rotation" and the lik
(defun c:Connected (/  _DynPop lbd ci lbp lb_IP np i civ chp npc ci_ip inter_P)
(defun _DynPop (o / data)
  (setq data (mapcar '(lambda (dp)
	     (list (vla-get-PropertyName dp)(vlax-get dp 'Value) dp))
		    (vlax-invoke o 'GetDynamicBlockProperties))
  (mapcar '(lambda (v) (cdr (assoc v data))) '("Angle1" "Distance1"))
(print "\nSelect Line Block")
  (if (and
	(setq lbd (ssget "_+.:S:E:L" '((0 . "INSERT")(2 . "LINE,`*U*"))))
	(princ "\nSelect Circle Block(s)")
	(setq ci (ssget "_:L" '((0 . "INSERT")(2 . "Circle,`*U*"))))
    	(eq "LINE" (strcase (vla-get-EffectiveName
			      (setq lbd (vlax-ename->vla-object (ssname lbd 0))))))
	(minusp (vlax-get lbd 'IsDynamicBlock))
    (progn
      (setq lbp (_DynPop lbd )
	    lb_IP (vlax-get lbd 'InsertionPoint)
	    np ( polar lb_IP (Caar lbp)(caadr lbp))
	    an (+ (/ pi 2) (angle lb_IP np)))
	(repeat (setq i (sslength ci))
	  	(setq civ (vlax-ename->vla-object (ssname ci (setq i (1- i)))))
	  (and
	    	(eq "CIRCLE" (strcase (vla-get-EffectiveName civ)))
	  	(setq cbp (_DynPop civ ))
	        (setq npc
		       (polar (setq ci_ip (vlax-get civ 'InsertionPoint))
			      an
			      (caadr cbp)
		(setq inter_P ( inters  lb_IP np ci_ip npc nil))
		(progn
			(vlax-put (cadar cbp) 'Value (angle ci_ip inter_P))
			(vlax-put (cadadr cbp) 'Value (distance ci_ip inter_P))
  (princ)
Message 15 of 26
abee123456789
Nice, I am pretty new to this what language is that and how do I start the process?
Thank you
Message 16 of 26
abee123456789
Is this possible using C# that is what ive been working with and I am fairly new.
Message 17 of 26
pbejse
Depending on the condition of the drawing, the program may not work as expected. The code I posted relies heavily on the current  Ängle1 Paramater value. So its more extending the end to the line and not always perpendicular, whilst @ВeekeeCZ offering will be perpendicular as you requested. But both will fail if the "circle" Block rotaion is other than 0
That is why I'm asking for a real scenario so we can make the proper adjustment to the code.
I usually use C# for sheet set processing , mostly data get/set data [ attributes / Xref /Layer infor ...]
For geometric manipulation, i stick with AutoLisp/Visual lisp.
I suggest you post your request here <-- Autocad .Net
HTH
Message 18 of 26
ВeekeeCZ
Step 3
(vl-load-com)
(defun c:Step3 ( / LM:setdynprops LM:getdynpropvalue :getpoints e p1 p2 ps s i)
  ;; Get Dynamic Block Property Value  -  Lee Mac ; http://www.lee-mac.com/dynamicblockfunctions.html#setdynamicprops
  (defun LM:getdynpropvalue ( blk prp )
    (setq prp (strcase prp))
    (vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'value)))
	     (vlax-invoke blk 'getdynamicblockproperties)))
  (defun :getpoints (e / o d p1 p2)
    (if (and  (setq o (vlax-ename->vla-object e))
	      (setq a (LM:getdynpropvalue o "Angle1"))
	      (setq d (LM:getdynpropvalue o "Distance1"))
	      (setq p1 (cdr (assoc 10 (entget e))))
	      (setq p2 (polar p1 a d))
      (list p1 p2)))
  (if (and (setq e (car (entsel "\nSelect block to split: ")))
	   (mapcar 'set '(p1 p2) (:getpoints e))
	   (setq ps (cons p2 ps))
	   (princ "\Select connections (blocks), ")
	   (progn (setq s (ssdel e s)) T)
    (progn
	(setq ps (cons (cadr (:getpoints (ssname s (setq i (1- i))))) ps)))
      (setq ps (vl-sort ps '(lambda (r1 r2) (< (distance p1 r1) (distance p1 r2)))))
      (LM:setdynprops (vlax-ename->vla-object e) (list (cons "Distance1" (distance p1 (car ps)))
						       (cons "Angle1" (angle p1 (car ps)))))
      (repeat (1- (length ps))
	(command "_.copy" e "" "_non" p1 "_non" (car ps))
	(LM:setdynprops (vlax-ename->vla-object (entlast)) (list (cons "Distance1" (distance (car ps) (cadr ps)))
								 (cons "Angle1" (angle (car ps) (cadr ps)))))
	(setq ps (cdr ps)))))
  (princ)
HERE 's a tutorial of how to use LISP.
Good luck.
Message 19 of 26
abee123456789
Attached i created a different scenario. Once again is this possible in C# .net That is what ive been missing around with lately. since i read some where that autodesk is going to discontinue lisp support.
Message 20 of 26
pbejse
Thank you for posting more samples. We will have a look see.
I replied to that at post # 17, Also, they've been saying that for years and yet it's still here 😊
Based on your latest sample, Are there no odd angles at all?
EDIT: Modified the code at post # 14 for perpendicular mode instead of Extend
