multiple xref with multiple drawings
michaelZCXYL
Message 1 of 8
michaelZCXYL
Is it possible to attach or detach multiple xref with multiple drawings at one time? thank you very much in advance. 🙂
Replies (7)
Message 2 of 8
paullimapa
Doing a search on-line like: "autolisp to remove xrefs from multiple drawings"
will give you some helpful links like this one:
adding xref into multiple drawings - AutoLISP, Visual LISP & DCL - AutoCAD Forums (cadtutor.net)
You can easily modify the script to detach xrefs as well. Of course if it's a nested xref then it won't be detached.
Though Autodesk used to develop ScriptPro to execute scripts on multiple drawings, this is no longer supported starting with Windows 10 64 bit.  But you can always download the free AutoScript:
AutoCAD Script Pro 64 bit - { Cadig AutoScript } - Freeware
Paul Li
IT Specialist
@The Office
Message 3 of 8
michaelZCXYL
Hello Paul,
Thank you very much for your information. There are some app to remove or detach xrefs. The adding xref is only to add the same xref to multiple drawings.  Is there any app to add or remove different xref to/from different drawings at one time? thanks again. 🙂
Message 4 of 8
paullimapa
dotsoft.com ToolPac app seems to contain the mulitple xref attach/detach to multiple drawings you're looking for:
Productivity Tools for AutoCAD, BricsCAD and IntelliCAD - ToolPac Software (dotsoft.com)
I've not used their apps so you'll have to contact them to confirm.
Paul Li
IT Specialist
@The Office
Message 5 of 8
michaelZCXYL
I will have a look when I have time, I am tied up right now, Many thanks. 🙂
Message 6 of 8
michaelZCXYL
Hello Paul,
The below is one of free tool website. just want to share with you, it is used to clean background, thanks.
https://forum.dwg.ru/showthread.php?p=735810#post735810
Message 7 of 8
paullimapa
Thanks for sharing these free tools...but it doesn't seem to provide a solution to your original post.
Paul Li
IT Specialist
@The Office
Message 8 of 8
michaelZCXYL
yes, it is not related to this topic. I think it is useful tool for me, I just want to share with you.
