Hi Jonathan, I've been using it in AutoCAD 2011 without much trouble, in fact v1.6 works with 2011 better than v1.4 (what I used to use). I just tried it in AutoCAD 2016 for a test and it seems to work ok for me, although I know the trouble spots well. User parameters (from block property tables) usually cause corruption unless you are careful. I often go back and edit old MVP blocks and I used to have to empty the block properties tables and delete any user parameters if I expected visibilityaddEngine to load, but with v1.6, I am able to load and work carefully with them in tact.
I figured out a workaround if you are trying to add something to a visibility set and it will not let you add it, it will usually not take unless you turn BVMODE to 1 just before you attempt to add the objects. Try BVMODE set to 1 before you try to remove the objects and see if that helps. Maybe first confirm that they are in the visibility set by checking (eddedd) first (grips on). I have to attempt adding to a visibility set sometimes multiple times - always starting the function over again and changing BVSHOW back to 1 (the glitch will cause it to switch back to 0 when it occurs). You'll know you've added an object when it appears greyed out.
I wonder if you have a good method worked out for creating or editing your MVP blocks. I always create as much of the block entities as I can to start, if a block property table will be in it I'll only put one parameter linked to it so that the grip will display, but no user parameters until the visibilities are finished. I create my first visibility, rename it VP_ALL_ON and I add two states to it - DEFAULT and ALL_ON. These make it easier to find objects later. I turn off objects that I want to be off by default in DEFAULT. I add visibility parameters from there and I always make the next one current, rename it, add the states then I remove everything EXCEPT what I want to keep in the visibility state using VSPDelSel - I'll issue the function, type "ALL" <enter> then R for remove and select what I intend to keep in the state. It works well for me.
Hope this helps.
ADN CAD Developer/Operator
