multiple layout export to separate CAD files
Message 1 of 14
Hi ,
I am looking for some help. I am trying to modify this layout export script from ahsattarian3 (see link https://forums.autodesk.com/t5/autocad-forum/export-multiple-layout-tabs-at-one-time-to-another-dwg/...
(prompt "\n Type : LXA ")
(defun c:lxa ()
  (setq layouts (layoutlist))
  (setq layouts (acad_strlsort layouts))
  (setq ad (getvar "dwgprefix"))
  (setq layfol (strcat ad "Layouts"))
  (vl-mkdir layfol)
  (setq f (strcat layfol "\\lxa.scr"))
  (setq ff (open f "w"))
  (write-line "model" ff)
  (foreach layout layouts
    (write-line "layout set" ff)
    (write-line (strcat "\"" layout "\"") ff)
    (setq adname (strcat (chr 34) layfol "\\" layout (chr 34)))
    (write-line "exportlayout" ff)
    (write-line adname ff)
  (close ff)
  (command "script" f)
Instead of the script saving the the cad file names as their "layout names", I would like to save them as their drawing number (which is a mtext in the paperspace of each layout and in the same coordinates on each sheet/layout) I think I need to do a ssget and window to get the txt string? and I assume it is AD definition that has been used? the coordinates are top right to bottom left in a window. x 775 y 25.34, x 740 y 17.3
I cant seem to get it to work at all and im sure a long way off but figured you might know how to do it efficiently. This is what I have below.
(defun c:lxa ()
(setq ad (if (ssget "_C"
'(775 25.34 0.0)
'(740 17.3 0.0)
'((0 . "*TEXT"))))
(vl-mkdir layfol)
(write-line layout ff)
(close ff)
thankyou!!
Replies (13)
Message 2 of 14
Sea-Haven
Try this (setq ad (ssget "F" (list '(775 25.34)'(740 17.3)) '((0 . "*TEXT"))))
Message 3 of 14
Keeps returning errors - (the selection set value keeps changing everytime i hit enter)
; error: bad argument type: stringp <Selection set: 5f>
(defun c:lxa ()
(vl-mkdir layfol)
(close ff)
Message 4 of 14
Sea-Haven
I think I misinterpreted what your doing your reading a text value somewhere in a layout and using that as part of the export name.
So the sequence should be
get all the layouts
loop through the layouts
look for the text and make the new dwg name
export the layout to a new dwg
end of loop.
So your "ad" should be within the foreach loop. There is no need to write a script just export each layout using (command............. .
More use (setvar 'ctab layout) to change to new layouts and then you need to do a pspace to make sure your in paper space.
Rather than me rewrite your code hopefully it makes sense what I am saying you have all the code just need to re-arrange it. Happy to help have a go 1st.
When doing something like this think about how you would do it manually I often write down on a piece of paper a shorthand did this then code.
Message 5 of 14
Yes correct - current script exports to cad and saves the file name as the layout name, where as i want it to save as a string of text in each layout (the drawing number for each layout)
i'll have a go and see what happens - appreciate it
Message 6 of 14
ronjonp
Maybe try using this as a base. It's more straight forward than writing a script to export tabs to separate drawings.
(defun c:layoutstodwgs (/ ct doc exprt fda lays msg pre)
  ;; https://www.theswamp.org/index.php?topic=19721.msg240359#msg240359
  (vl-load-com)
  (setq	fda   (getvar 'filedia)
	pre   (getstring "\n Enter filename prefix: ")
	exprt (getvar 'expert)
	ct    (getvar 'ctab)
	doc   (vla-get-activedocument (vlax-get-acad-object))
	lays  (vla-get-layouts doc)
	msg   ""
  (setvar 'filedia 0)
  (setvar 'expert 5)
  (setvar 'tilemode 1)
  (command "_ucs" "_w")
  (foreach l (layoutlist)
    (setvar 'ctab l)
    (if	(> (sslength (ssget "_x" (list (cons 410 (getvar 'ctab))))) 1)
      (progn (vla-endundomark doc)
	     (vla-startundomark doc)
	     (vlax-for x lays
	       (and (/= (vla-get-name x) (getvar 'ctab)) (vl-catch-all-apply 'vla-delete (list x)))
	     (command "_-.wblock" (strcat (getvar 'dwgprefix) pre l) "*")
	     (setq msg (strcat (getvar 'dwgprefix) pre l ".dwg created.\n" msg))
	     (command "_u")
      (setq msg (strcat "Tab " l " has nothing on it and skipped.\n" msg))
  (setvar 'filedia fda)
  (setvar 'expert exprt)
  (setvar 'ctab ct)
  (princ msg)
Message 7 of 14
Sea-Haven
So to clarify you want layout names to be changed. Ok you get the text value then so
get name do your thing
(vla-put-name layout newname)
Message 8 of 14
Nope - cad file stays the same. no layouts change. Just the exported cad file name to change. (to suit the mtext string that is in the layout)
Message 9 of 14
ronjonp
Maybe something as simple as this?
(defun c:foo (/ ad)
  (setvar 'filedia 0)
    (setvar 'ctab l)
    (command "_.exportlayout"
		     ;; Assumes that your text is visible for the fence selection
		     ;; Your sample drawing has nothing to select at the coordinates listed below
		     (if (setq ad (ssget "_F" (list '(775 25.34) '(740 17.3)) '((0 . "*TEXT"))))
		       (cdr (assoc 1 (entget (ssname ad 0))))
		       l
		     ".dwg"
  (setvar 'filedia 1)
Message 10 of 14
maratovich
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 11 of 14
ronjonp
@maratovich  Will your program grab text from a certain location on each tab and and use that as the name?
Message 12 of 14
maratovich
Yes.
Please attach an example of your file.
www.kdmsoft.net
Message 13 of 14
perfect thankyou so much!!!
Message 14 of 14
Amriya_Exe
Working nice for my purpose.
