Multiple layers select Lisp
k005
Advisor Advisor
Message 1 of 8
k005
Hello friends
How can I make multiple selections and select all objects in the relevant layer?
Replies (7)
Message 2 of 8
pbejse
@k005 wrote:
Hello friends
What do you mean multiple? multiple objects of the same type or one just one type of object?
This line will prompt the user to select "LWPOLYLINE" with "Drainpipe" layer  on screen
(setq ss (ssget '((0 . "LWPOLYLINE")(8 . "Drainpipe"))))
This will select all "LWPOLYLINE" with "Drainpipe" layer on "Model" space without user prompt
(setq ss (ssget "_X" '((0 . "LWPOLYLINE")(8 . "Drainpipe")(410 . "Model"))))
This will select all "LWPOLYLINE" and/or "INSERT" (blocks)  with "Drainpipe" layer on "Model" space without user prompt
(setq ss (ssget "_X" '((0 . "LWPOLYLINE,INSERT")(8 . "Drainpipe")(410 . "Model"))))
 HTH
Message 3 of 8
Kent1Cooper
If you want to select objects of any type, and find all objects of any type on the Layers of those selected objects, try using LAYISO.  It will turn off all the Layers other than those of the selected objects, and you should then be able to just select everything visible.  LAYUNISO turns those other Layers back on.
This will be complicated by the possibility of objects on such Layers that are nested in Blocks inserted on other Layers, but I expect that will be a complication of any approach.
Kent Cooper, AIA
Message 4 of 8
k005
@pbejse
First of all, sorry for my late reply...
Now let me explain: The lisp code at the bottom only selects the X layer and ends.
What I want to do is select All objects belonging to both X, Y and N layers.
X Y N --» given as the symbolic layer name.
(defun C:SEL ( / e lay ss)
 (setq e (nentsel "Select entity on a layer: "))
 (if e (setq ss (ssget "_X" (list(cons 8 (cdr (assoc 8 (entget (car e)))))))))
 (if (zerop (getvar"CMDACTIVE"))
  (progn (sssetfirst ss ss)(princ"Use 'P' for this selection set: "))
 ss
Message 5 of 8
k005
@Kent1Cooper
It would be much more useful if we could do it via Lisp.
Message 6 of 8
pbejse
The program enables the user to select an object
and then proceeds to retrieve the layer of the selected entity
and use the value of the layer as a filter for ssget
		    (list (cons 8 (cdr (assoc 8 (entget (car e))))))
Naturally, an object can only have one layer.
Now , what we an do is to modify the code to prompt the user to continue selecting an entity in a loop, build a list of layer names, and use that for the filter.
(defun C:SEL (/ e lay ss lname layerlist)
  (While
    (setq e (nentsel "\nSelect entity on a layer: "))
    (princ (strcat "\nSelected entity layer name "
		   (setq lname (cdr (assoc 8 (entget (car e)))))
    (setq layerlist (cons lname layerlist))
    (redraw (car e) 3)
  (setq ss (ssget "_X" (list (cons 8
			 (apply 'strcat (mapcar '(lambda (n)
						   (strcat n ",")) layerlist)
  (if (zerop (getvar "CMDACTIVE"))
	   (princ "Use 'P' for this selection set: ")
  ss
HTH
Message 7 of 8
k005
@pbejse
Thank you very much. It's ok. 🤗
Message 8 of 8
mkmkameniar
Hi @pbejse, your lisp works perfectly. However, would it be possible to change it to work with blocks too? I mean, when I run the lisp and click on the block in a particular layer, it wouldn't choose objects from this layer, but from layer of the nested object in block (which is in my case 0).
