Hi guys, can you write 2 simple lisps that allow quick Multiple Fillet
(I mean without pressing enter after use command Fillet) (in 2D/3D) :
F0 - Multiple - Fillet - Radius [0]
FR - Multiple - Fillet - Radius [User_add_value]
Solved by ВeekeeCZ. Go to Solution.
Solved by komondormrex. Go to Solution.
Ou man, this is like virus.. I can't escape the lisp. Esc/Enter not working. I must exit Autocad by windows task manager..
oops, i got it the same on the other version.
these ones stops on the Esc.
(defun c:f0 nil
(setvar 'filletrad 0)
(while (null (command "_fillet" pause pause)))
(defun c:fr (/ radius)
(if (setq radius (if (null radius)
(getreal (strcat "\nEnter radius to fillet with <" (rtos (getvar 'filletrad)) ">: "))
(getvar 'filletrad)
(setvar 'filletrad radius)
updated
Another just type F123 etc f2 and so on the number is used as the radius for the fillet, note as this uses a reactor catching an error you need to do this for say rad 3.5, f3-5 as the "." is detected in the error trap.
Another version is offset and Circles.
; Fillet rad uses Frad eg f100 pulls the 100 from the F and then runs fillet
; BY Alan H 2019
( (lambda nil
(vl-load-com)
(foreach obj (cdar (vlr-reactors :vlr-command-reactor))
(if (= "fillet-reactor" (vlr-data obj))
(vlr-remove obj)
(vlr-command-reactor "fillet-reactor" '((:vlr-unknowncommand . fillet-reactor-callback)))
(defun filletrad ( / rad)
(setq rad (distof (substr com 2) 2))
(if (<= 0.0 rad)
(progn
(setvar 'filletrad rad)
(vla-sendcommand fillet-reactor-acdoc "_.fillet ")
(defun fillet-reactor-callback ( obj com )
(setq com (vl-string-translate "-" "." (strcase (car com))))
(cond
( (and
(wcmatch com "~*[~F.0-9]*")
(wcmatch com "F*")
(wcmatch com "~F*F*")
(wcmatch com "~*.*.*")
) ; and
(filletrad)
) ; master cond
) ; defun
(or fillet-reactor-acdoc
(setq fillet-reactor-acdoc (vla-get-activedocument (vlax-get-acad-object)))
