Multiple DXF Import
Multiple DXF Import
prajputZ23VK
Multiple DXF Import
prajputZ23VK
I am using below lisp code to import multiple DXF files into my drawing. But the issue is when I import all the DXF files, those gets overlapped. Is there any possibility to move the each DXF files in horizontal direction during import, so that they don’t overlap?
(defun c:PR (/ directory files)
 (setq directory "C:\\Temp\\Automation")
 (if (setq files (vl-directory-files directory "*.dxf" 1))
   (foreach dxf files
     (command "_.-insert"
              (strcat directory "\\" dxf)
              '(0. 0. 0.)
   (princ "\n No DXF files found into that folder !")
 (princ)
Thanks in advance for help.
hak_vz
 (setq origin '(-1000  0 0) step '(1000 0 0))
   (foreach dxf files
     (setq origin (mapcar '+ origin step))
              origin
 (princ)
Each next origin for a block insert is translated 1000 in x direction starting from '(0 0 0).
Miljenko Hatlak
maratovich
Maybe this will help you - AutoImportCAD
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
prajputZ23VK
Hello hak_vz,
Thank you for your quick help. Your code helped me achieving what I was looking for.
Thanks again.
PR
