Multiple block translation
Bart_Dheere
Bart_Dheere
Is it possible to find some program to translate multiple blocks into other blocks? All at once?
grtz,
Bart
patrick_35
Hi
With Rbloc ?
Kent1Cooper
I use BlockReplace.lsp, available here.  It can replace only Blocks that you Select [the BRS command] or All Blocks of the same name as one you select [the BRA command].
Kent Cooper, AIA
