Multileader tag's counter
F.Camargo
Advisor Advisor
Message 1 of 10
F.Camargo
Hello everyone!
How are you?
Is it possible to create a list to count a specific tag in my multileader?
e.g
8 = 1
9 = 1
10 = 1
Or somenthing like that.
Fabricio
Accepted solutions (3)
Replies (9)
Message 2 of 10
Moshe-A
@F.Camargo  hi,
the answer is yes
(defun c:mlctr (/ ss ename elist val eitem nitem lst)
 (if (setq ss (ssget '((0 . "multileader"))))
  (progn
   (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
    (setq elist (entget ename))
    (setq val (atoi (cdr (assoc '302 (reverse elist)))))
    (if (null (setq eitem (assoc val lst)))
     (setq lst (cons (list val 1) lst))
     (progn
      (setq lst (vl-remove eitem lst))
      (setq nitem (list (car eitem) (1+ (cadr eitem))))
      (setq lst (cons nitem lst))
     ); progn
    ); if
   ); foreach
   (foreach item (vl-sort lst (function (lambda (e0 e1) (< (car e0) (car e1)))))
    (prompt (strcat "\n" (itoa (car item)) " = " (itoa (cadr item))))
  ); progn
 ); if
 (princ)
Message 3 of 10
ВeekeeCZ
Or by tag name...
(Defun c:listofattvalues ( / s g l lg lv k)
  (and (setq s (ssget '((0 . "MULTILEADER"))))
       (setq g (getstring "tag: "))
       (setq l (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
       (setq lg (mapcar '(lambda (e) (vl-remove-if '(lambda (p) (/= (car p) 330)) (member (assoc 344 (entget e)) (entget e)))) l))
       (setq lg (apply 'append (mapcar '(lambda (x) (mapcar '(lambda (y) (cdr (assoc 2 (entget (cdr y)))) )x)) lg)))
       (setq lv (mapcar 'cdr (apply 'append (mapcar '(lambda (e) (vl-remove-if '(lambda (p) (/= (car p) 302)) (member (assoc 344 (entget e)) (entget e)))) l))))
       (setq l (mapcar 'cons lg lv))
       (setq l (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) g)) l)))
       (foreach e l (setq k (if (setq a (assoc e k))
			      (subst (cons e (1+ (cdr a))) a k)
			      (cons (cons e 1) k))))
       (setq k (vl-sort k '(lambda (e1 e2) (< (car e1) (car e2)))))
  k
Message 4 of 10
F.Camargo
Awesome!!! Fantastic.
Thank you
Message 5 of 10
F.Camargo
Thank for the help!
When I input the tag like number 8, its return nil.
Am i doing something wrong?
Message 6 of 10
ВeekeeCZ
You apparently use wrong terminology.
Attributes have names called TAGs and it's values. If you explode your MLEADER so you get an access to block, you can use EATTEDIT to reveal att description.
Or can use the Properties Palette.
Sort the atts by tags makes only sense if you have more attributes than 1.
Message 7 of 10
komondormrex
hey you there,
check this yet another even vlaxed one.
(defun parse_list (_list / unique_list old_member)
	(foreach _member _list (if (not (member _member unique_list)) (setq unique_list (append unique_list (list _member)))))
	(setq unique_list (mapcar '(lambda (_member) (cons _member 0)) unique_list))
		(if (setq old_member (assoc _member unique_list))
				(setq unique_list (subst (cons (car old_member) (1+ (cdr old_member))) old_member unique_list))
(defun get_mleaders (/ mleader_sset mleader_list )
	(prompt "\nPick \"_TagCircle\" mleaders to count by attribute value...")
	(if (setq mleader_sset (ssget '((0 . "multileader"))))
		(setq mleader_list (parse_list
								(mapcar '(lambda (mleader) (vlax-map-collection (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
																						  "_TagCircle"
															'(lambda (object) (if (= "AcDbAttributeDefinition" (vla-get-objectname object))
																				(setq att_id (vla-get-objectid object))
														   (vla-getblockattributevalue mleader att_id)
										 (vl-remove-if-not '(lambda (mleader) (= "_TagCircle" (vla-get-contentblockname mleader)))
				   					   					  		(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex mleader_sset))))
(defun c:count_mleader nil
	(terpri)
	(mapcar '(lambda (mleader) (princ (strcat "\"" (car mleader) "\" = " (itoa (cdr mleader)))) (terpri))
			 (get_mleaders)
	(princ)
Message 8 of 10
F.Camargo
Worked fine!!
Thank you so much.
Message 9 of 10
F.Camargo
Impressive guys!!
you are awesome!!!
Message 10 of 10
Sea-Haven
Check your other post also at The Swamp.
Supported by Bricscad V25 is short code, the USIL & DSIL are tag names. Sorry not in Acad.
(setq blkent (car (entsel "\nPick leader ")))
(setq il1 (atof  (getpropertyvalue blkent "USIL~BlockAttribute")))
(setq il2 (atof  (getpropertyvalue blkent "DSIL~BlockAttribute")))
