Multileader style with movable attributes
Does anyone know if its possible to create a multileader style that has a block with attributes that you can pick on & move the attribute text? When i use the block when not part of the multileader style i can select the grips & move the text but when it is part of the multileader style i cannot.Is there a variable that controls this?
dmfrazier
"Is there a variable that controls this?"
Apparently not. (But it does seem like a good idea.)
Edwin.Saez
There is no variable for this.
But the solution to what you need is to create your callout as a dynamic block.
Edwin Saez
LinkedIn / AutoCAD Certified Professional
Si mi respuesta fue una solución para usted, por favor seleccione "Aceptar Solución", para que también sirva a otro usuarios.
