Mtext replace color
Mtext replace color
msarqui
Message 1 of 26
Mtext replace color
msarqui
Hi everyone,
I have a tricky one...
I have a hundred Mtexts on the Bylayer color. In those Mtexts, I have some words on the Red color, some on the Green color and some on the Blue color, for office standards purposes.
Is there a way to have a routine that allows to select one Mtext at a time and then swap only the Red colored words for another color, like for exemple 216, without change the Green or the Blue colored words?
It will be something like the Find and Replace command, but with color formatting option...
Thanks!
Replies (25)
Message 21 of 26
hmsilva
Hi Marcelo,
I have a deadline to meet today, so tonight or tomorrow, I'll see what I can do.
Henrique
Message 22 of 26
hmsilva
Hi Marcelo,
let's see if this is what you need...
(quickly written, and few tests)
(vl-load-com)
(defun c:ChangeTextColor (/ ch_str_color att attlst flag name new i obj objn old ss)
  (defun ch_str_color (str old new /)
    (while (vl-string-search (strcat "\\C" (itoa old) ";") str)
      (setq str (vl-string-subst
                  (strcat "\\C" (itoa new) ";")
                  str
                );vl
      );setq str
    );while
    str
  );;ch_str_color
  (or acdoc (setq acdoc (vla-get-activedocument (vlax-get-acad-object))))
  (if (and (princ "\n Select Text, Mtext or Attribute object to change its color: ")
           (setq ss (ssget "_:L" '((0 . "MTEXT,TEXT,INSERT"))))
           (setq old (getint "\n Enter the old color number: "))
           (<= 0 old 256)
           (setq new (getint "\n Enter the new color number: "))
           (<= 0 new 256)
      );and
    (repeat (setq i (sslength ss))
      (setq obj  (vlax-ename->vla-object (ssname ss (setq i (1- i))))
            objn (vla-get-objectname obj)
      );setq
      (cond ((= objn "AcDbMText")
             (vla-put-textstring obj (ch_str_color (vla-get-textstring obj) old new))
            ((and (= objn "AcDbText")
                  (= (vla-get-color obj) old)
             );; and
             (vla-put-color obj new)
            ((= objn "AcDbBlockReference")
             (cond ((and (= (vla-get-hasattributes obj) :vlax-true)
                         (setq attlst (vlax-invoke obj 'GetAttributes))
                         (progn (foreach att attlst
                                  (if (= (vla-get-mtextattribute att) :vlax-true)
                                    (setq flag T)
                                  flag
                    );; and
                    (progn
                      (foreach att attlst
                        (if (= (vla-get-mtextattribute att) :vlax-false)
                          (if (= (vla-get-color att) old)
                            (vla-put-color att new)
                          );; if
                          (vla-put-textstring att (ch_str_color (vla-get-textstring att) old new))
                        );; if
                      );; foreach
                      (setq flag nil)
                    );; progn
                   ((= (vla-get-hasattributes obj) :vlax-true)
                    (setq name (vla-get-effectivename obj))
                    (vlax-for blks (vla-get-blocks acdoc)
                      (if (and (= (vla-get-objectname blks) "AcDbBlockTableRecord")
                               (= (vla-get-name blks) name)
                          );; and
                        (progn
                          (vlax-for blk blks
                            (if (and (= (vla-get-objectname blk) "AcDbAttributeDefinition")
                                     (= (vla-get-color blk) old)
                                );; and
                              (progn
                                (vla-put-color blk new)
                                (setq flag T)
                              );; progn
                            );; if
                          );; vlax-for
                        );; progn
                      );; if
                    );; vlax-for
                    (if flag
                      (progn
                        (command "_.attsync" "_N" name)
                        (setq flag nil)
                      );; progn
                    );; if
                   (T
                          );; and
                        (progn
                          (vlax-for blk blks
                            (cond ((= (vla-get-objectname blk) "AcDbMText")
                                   (vla-put-textstring blk (ch_str_color (vla-get-textstring blk) old new))
                                   (setq flag T)
                                  ((and (= (vla-get-objectname blk) "AcDbText")
                                   );; and
                                   (setq flag T)
                            );; cond
                          );; vlax-for
                          (if flag
                            (progn
                              (vla-regen acdoc 1)
                              (setq flag nil)
                            );; progn
                          );; if
                        );; progn
                      );; if
                    );; vlax-for
             );; cond
      );; cond
    );; repeat
  );; if
  (princ)
Hope this helps,
Henrique
Message 23 of 26
msarqui
I am testing...
Message 24 of 26
msarqui
Tested and approved. Thank you very much Henrique!
Message 25 of 26
hmsilva
You're welcome, Marcelo!
Glad I could help
Henrique
Message 26 of 26
Jaxom26
This routine works perfectly, but I have an added issue. I have some items that have a True Color value to them, like 0,0,0 for black or 255,0,0 for red. Is it possible to modify this routine to allow for True Color values being changed to a standard AutoCAD 1 - 256 color?
