Dynamic Input after running LSP
01:11 AM
I have made some simple lsp commands to make printing pdf, dwf and A3 a one click affair. For some reason though, after using one of the commands it will turn on dyanmic input (F12) and I have no idea why, what am I missing?
(defun c:PPDF(/) ;; make sure filename is ok before plotting (if (setq filename (getfiled "enter actobat file name" "" "pdf" 1)) (progn (command "tilemode" "0") (command "-plot" "y" "" "Dwg To PDF.pc3" "ISO full bleed A1 (841.00 x 594.00 MM)" "M" "L" "N" "e" "1:1" "" "Y" "" "Y" "N" "N" "N" filename "y" "Y") )) (princ) ) (defun c:PDwF(/) ;; make sure filename is ok before plotting (if (setq filename (getfiled "enter actobat file name" "" "dwf" 1)) (progn (command "tilemode" "0") (command "-plot" "y" "" "DWF6 ePlot.pc3" "ISO full bleed A1 (841.00 x 594.00 MM)" "M" "L" "N" "e" "1:1" "" "Y" "" "Y" "N" "N" "N" filename "y" "Y") )) (princ) ) (defun c:A3p(/) (command "tilemode" "0") (command "-plot" "y" "Layout1" "\\\\CTASERVER\\Brother MFC-6490CW Printer" "A3" "M" "L" "N" "e" "F" "" "Y" "" "Y" "y" "N" "N" "n" "Y" "y" ) )) (princ) )
