Mtext background mask offset default
john.uhden
Mentor Mentor
john.uhden
I 've googled around and found for myself that DXF 45 can be modified to change the offset, but where is the default stored?  It seems to be 1.5 but I'd rather have a default of 1.1.  Yes, I've already created a c:backgroundoffset function, but it seems stupid to have to post-process.  You know... you may have to unlock layers and then lock them again.  Yeah, I can automate that too, but I prefer to have MY defaults.
John F. Uhden
artc2
The default of 1.5 is hardcoded in the acdb dll.
Ranjit_Singh
Maybe give this a try.
john.uhden
There it is, in C3D 2014 as well.  Except that changing it in the registry had no effect.  In fact it seemed to change the default to 0.0 in AutoCAD, which of course is not allowed.  The factor must be >= 1 and preferably <= 5.
I changed the value in...
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.1\ACAD-D000:409\MTEXT
which apparently automatically updated
HKEY_USERS\S-1-5-21-3174490996-1184374969-4093637027-1000\Software\Autodesk\AutoCAD\R19.1\ACAD-D000:409\MTEXT
Maybe you need to restart AutoCAD for it to take effect.
John F. Uhden
Those simple objectarx code can auto add background to mtext .
#pragma warning( push)
#pragma warning (disable: 4189 4100 )
#include <Windows.h>
#include <arxHeaders.h>
#pragma warning( pop)
class EditorReactor :
	public AcEditorReactor {
public:
	inline void databaseConstructed(AcDbDatabase*);
class DatabaseReacotr :
	public AcDbDatabaseReactor {
public:
	inline void objectAppended(
		const AcDbDatabase*,
		const AcDbObject* dbObj) /*override*/ {
		AcDbMText * varMtext = AcDbMText::cast(dbObj);
		if (varMtext) {
			double varBF = 0;
			varMtext->getBackgroundScaleFactor(varBF);
			if (std::abs(varBF - 1.005) < 0.0001) {
				return;
			if (Acad::eOk == varMtext->upgradeOpen()) {
				varMtext->setBackgroundFill(true);
				varMtext->setUseBackgroundColor(true);
				varMtext->setBackgroundScaleFactor(1.005);
DatabaseReacotr * globalDatabaseReacotr = 0;
EditorReactor *   globalEditorReactor   = 0;
void EditorReactor::databaseConstructed(AcDbDatabase* var) {
	var->addReactor(globalDatabaseReacotr);
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* pkt) {
	switch (msg) {
	case AcRx::kInitAppMsg: {
		acrxDynamicLinker->unlockApplication(pkt);
		acrxRegisterAppMDIAware(pkt);
		globalDatabaseReacotr = new DatabaseReacotr;
		globalEditorReactor = new EditorReactor;
		acedEditor->addReactor(globalEditorReactor);
		break;
	case AcRx::kUnloadAppMsg: {break;}
	default:break;
	return AcRx::kRetOK;
john.uhden
Thanks, but that code doesn't look "simple" to me.
It doesn't really matter though since I can change the DXF 45 value using AutoLisp.
John F. Uhden
