Convert Text into Field
This Lisp is used to Lable the coordinate with Leader.
I want this Lable as a field "Not text",
Please Edit it for me.
;cord-ldr.lsp
; x,y Coordinates on Leader Lines
(defun C:CR (/ PNT1 P1X P1Y STDY DY COORD PTXT)
(setq PNT1 (getpoint
"\nPick coordinate point: "))
(setq P1X (car pnt1)) ;x coord
(setq P1Y (cadr pnt1)) ;y coord
(setq STDX (rtos P1X 2 4))
(setq STDY (rtos P1Y 2 4))
(setq COORD (strcat "E" STDX)
COORD1(strcat "N" STDY))
(setq PTXT (getpoint PNT1
"\nPick text location: "))
(command "LEADER" PNT1 PTXT ""
COORD COORD1 "" "")
(princ)) ; end
(ALERT "IT WILL PRINT THE X,Y CO-ORDINATES OF A POINT..., C:CR")
cadffm
Leader objecttype can not be used for it,
or can you create a field (manually), which reads the desired information? command: field
Perhaps you are happy with your own dynamic-Block for a "leader",
but leader and mleader have no "origin" to extract with fields, sorry.
Sebastian
CADaSchtroumpf
Isn't a Leader, but can be similar to, and the fields are used
The coordinates are all way be show from WCS
(defun c:coord-xy_field ( / AcDoc Space pt_pos pt_field htx rtx ncol ocs op dlt1 dlt2 obj js nw_obj l_max lst_pt p1 p2 p3 nw_pl)
  (vl-load-com)
  (setq
    AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
    Space
    (if (= 1 (getvar "CVPORT"))
      (vla-get-PaperSpace AcDoc)
      (vla-get-ModelSpace AcDoc)
  (while (setq pt_pos (getpoint "\nPick coordinate point: "))
    (initget 9)
    (setq pt_field (getpoint pt_pos "\nPick text location: "))
    (initget 6)
    (setq htx (getdist pt_field (strcat "\nSpecify the field height <" (rtos (getvar "TEXTSIZE")) ">: ")))
    (if htx (setvar "TEXTSIZE" htx))
    (if (not (setq rtx (getorient pt_field "\nSpecify the field orientation <0.0>: "))) (setq rtx 0.0))
    (setq
      ncol '(131 160)
      ocs (trans '(0.0 0.0 1.0) 1 0 T)
      op (if (and (> (angle pt_pos pt_field) (* pi 0.5)) (<= (angle pt_pos pt_field) (* 1.5 pi))) T nil)
      dlt1
      (list
        ((if op + -) (* (getvar "TEXTSIZE") (cos rtx)) (* (* (getvar "TEXTSIZE") 0.5) (sin rtx)))
        ((if op - +) (* (getvar "TEXTSIZE") (sin rtx)) (* (* (getvar "TEXTSIZE") 0.5) (cos rtx)))
        0.0
      dlt2
      (list
        ((if op + -) (* (getvar "TEXTSIZE") (cos rtx)) (* (- (* (getvar "TEXTSIZE") 0.5)) (sin rtx)))
        ((if op - +) (* (getvar "TEXTSIZE") (sin rtx)) (* (- (* (getvar "TEXTSIZE") 0.5)) (cos rtx)))
        0.0
    (foreach n '("Id-XY" "Id-Point")
      (cond
        ((null (tblsearch "LAYER" n))
          (vlax-put (vla-add (vla-get-layers AcDoc) n) 'color (car ncol))
      (setq ncol (cdr ncol))
    (cond
      ((null (tblsearch "STYLE" "Coord-Field"))
        (setq nw_style (vla-add (vla-get-textstyles AcDoc) "Coord-Field"))
        (mapcar
          '(lambda (pr val)
            (vlax-put nw_style pr val)
          (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag)
          (list (strcat (getenv "windir") "\\fonts\\arial.ttf") 0.0 (/ (* 15.0 pi) 180) 1.0 0.0)
    (vlax-put (vla-AddPoint Space (vlax-3d-point (trans pt_pos 1 0))) 'layer "Id-Point")
    (setq obj (entlast) js (ssadd))
    (mapcar
      '(lambda (lx)
        (apply
          '(lambda (ins_point value_field att_point txt_height dwg_dir v_norm txt_rot name_style name_layer / nw_obj)
            (setq nw_obj
              (vla-addMtext Space
                (vlax-3d-point ins_point)
                0.0
                (strcat
                  "%<\\AcObjProp.16.2 Object(%<\\_ObjId "
                  (itoa (vla-get-ObjectID (vlax-ename->vla-object obj)))
                  value_field
              js (ssadd (entlast) js)
            (mapcar
              '(lambda (pr val)
                (vlax-put nw_obj pr val)
              (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'Normal 'Rotation 'StyleName 'Layer)
              (list att_point txt_height dwg_dir ins_point v_norm txt_rot name_style name_layer)
          lx
      (list
        (list
          (trans (if op (mapcar '- pt_field dlt1) (mapcar '+ pt_field dlt1)) 1 0)
          ">%).Coordinates \\f \"%lu2%pt1%pr3%ps[E ,]\">%"
          (if op 9 7)
          (getvar "TEXTSIZE")
          5
          ocs
          rtx
          "Coord-Field"
          "Id-XY"
        (list
          (trans (if op (mapcar '- pt_field dlt2) (mapcar '+ pt_field dlt2)) 1 0)
          ">%).Coordinates \\f \"%lu2%pt2%pr3%ps[N ,]\">%"
          (if op 3 1)
          (getvar "TEXTSIZE")
          5
          ocs
          rtx
          "Coord-Field"
          "Id-XY"
    (setq l_max nil)
    (foreach n (append (textbox (list (assoc 1 (entget (ssname js 0))))) (textbox (list (assoc 1 (entget (ssname js 1)))))) (setq l_max (cons (apply 'max n) l_max)))
    (setq
      l_max (apply 'max l_max)
      lst_pt
      (list
        (trans pt_pos 1 ocs)
        (trans pt_field 1 ocs)
        (trans (setq p1 (polar pt_field (+ rtx (* 0.5 pi)) (* 2.0 (getvar "TEXTSIZE")))) 1 ocs)
        (trans (setq p2 (polar p1 (if op (+ pi rtx) rtx) (+ l_max (* (getvar "TEXTSIZE") 3.0)))) 1 ocs)
        (trans (setq p3 (polar p2 (- rtx (* 0.5 pi)) (* 4.0 (getvar "TEXTSIZE")))) 1 ocs)
        (trans (polar p3 (if op rtx (+ pi rtx)) (+ l_max (* (getvar "TEXTSIZE") 3.0))) 1 ocs)
    (setq nw_pl
      (vlax-invoke Space 'AddLightWeightPolyline
        (apply 'append (mapcar 'list (mapcar 'car lst_pt) (mapcar 'cadr lst_pt)))
    (vlax-put nw_pl 'Closed 1)
    (vlax-put nw_pl 'Elevation (caddr (trans (trans pt_pos 1 0) 0 1 T)))
    (vlax-put nw_pl 'Layer "Id-XY")
  (prin1)
1. The text is not Field.
2. Asking height every time & Orientation. (Should Follow existing Dimension Style.
