MS Scale
MS Scale
MS Scale
Why does one model space drawing not copy and paste into another model space drawing at the correct scale but pastes so small you can hardly see it even if you set both file drawing units to the same?
Jonathan3891
The units are probably different. I cant open the files you created becuase they were created with newer versions.
Check the units in both drawings.
Jonathan Norton
Blog | Linkedin
doni49
DSM is correct.
I was able to open the files.   One is set for METERS and the other is set for FEET.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
doni49
Hmm.  Now I see what you mean though.
It doesn't seem to matter what happens when you change units (on either side of the exchange).  In the following image, as you can see, the acoustic file is open.  I pasted the other file in three different times -- each one with the units set as shown.  I tried changing the units in both the source file and the destination.  It all gets the same results.
Don Ireland
Kent1Cooper
@Anonymous_dude wrote:
.... I cant open the files you created becuase they were created with newer versions.
(If you install AutoDesk's free DWG TrueView program, one of its capabilities is to convert newer-version .dwg files back to whatever version you have [within limits].)
Kent Cooper, AIA
