mpcar and lambda
mpcar and lambda
luizhcastanho
mpcar and lambda
luizhcastanho
I'm a beginner!
I'm multiplying and summing block attributes from a list.
somaml 0
60 x 2 = 120
somaml 120
320 x 4 = 1280
somaml 1400
170 x 9 = 1530
somaml = 2930
n
; error: too few arguments
(defun c:teste()
(setq somaml 0)
(setq lst (list "L1 60 2" "L2 320 4" "L3 170 9"))
	(foreach lst
		(setq somaml (+ (mapcar (function (lambda (x y) (* atoi (nth 1 x) atoi (nth 2 y)))) lst) somaml))
(princ somaml)
Kent1Cooper
The error message is probably from the fact that (foreach) needs an item indicator:
  (foreach item lst ....
and then something in the following code needs to refer to item pulling information from each text string in the list.  I haven't fully analyzed the long line yet, but I notice what looks like (nth 1 x) is trying to pull [for example] the "60" out of "L1 60 2", but (nth) is for pulling an item out of a list, not a substring out of a longer string.
EDIT:  A different approach, greatly simplified if you can make your list a list of lists, not a list of text strings, with each sub-list containing a string and two integers:
(setq
  lst '(("L1" 60 2) ("L2" 320 4) ("L3" 170 9))
  somaml (apply '+ (mapcar '(lambda (x) (* (nth 1 x) (nth 2 x))) lst))
With your list of text strings, they have to be pulled apart to separate the pieces around the spaces.  There are routines available to do that, but a list formatted more appropriately for the purpose makes it much easier.
Kent Cooper, AIA
komondormrex
(defun c:teste()
	(setq somaml 0)
	(foreach string (list "L1 60 2" "L2 320 4" "L3 170 9")
		(setq somaml (+ somaml (apply '* (cdr (read (strcat "(" string ")"))))))
	(princ somaml)
marko_ribar
Someone is quicker ... 🙂
(defun c:teste ( / somaml lst xl )
  (setq somaml 0)
  (foreach x lst
    (setq xl (read (strcat "(" x ")")))
    (setq somaml (+ somaml (* (cadr xl) (caddr xl))))
  (prompt "\nsomaml : ") (princ somaml)
  (princ)
Marko Ribar, d.i.a. (graduated engineer of architecture)
luizhcastanho
I think I expressed myself wrong. The lst is a list of attribute list.
Something like that:
(setq lst (list ("L1" "60" "2") ("L2" "320" "4") ("L3 "170" "9")))
The list is generated by selecting all blocks, with their respective attributes:
    (setq int -1 sel (ssget "x" (list (cons 0 "INSERT") (cons 410 "Model"))))
    (while (setq int (1+ int) ent (ssname sel int))
      (setq ord nil qty nil itm nil)
      (while
        (/= (cdr (assoc 0 (setq get (entget (setq ent (entnext ent))))))
            "SEQEND"
         (setq tag (cdr (assoc 2 get))
               str (cdr (assoc 1 get))
         (vl-some (function (lambda (j k) (and (= tag j) (set k str))))
                  '("CÔMODO" "QTD" "COMPRIMENTO")
                  '(ord qty itm)
      (and ord
           itm
           qty
           (or (vl-some
                 '(lambda (u)
                    (and (eq (car u) ord)
                         (eq (cadr u) itm)
                         (setq
                           lst (subst (list ord
                                            itm
                                            (vl-princ-to-string
                                              (+ (read qty) (read (caddr u)))
                                      u
                                      lst
                 lst
               (setq lst (cons (list ord itm qty) lst))
      lst
Kent1Cooper
That would need to be:
(setq lst (list '("L1" "60" "2") '("L2" "320" "4") '("L3 "170" "9")))
or:
(setq lst '(("L1" "60" "2") ("L2" "320" "4") ("L3 "170" "9")))
Then somaml becomes:
(apply '+ (mapcar '(lambda (x) (* (atoi (nth 1 x)) (atoi (nth 2 x)))) lst))
Kent Cooper, AIA
Sea-Haven
Agree with you Kent about make list, this is like part 2 of another post and missing information in that post also,
The lst can retain the numbers and the alpha. Look at 1st post about 60*2.
(setq lst (list '("L1" 60 2) '("L2" 320 4) '("L3" 170 9)))
or:
(setq lst '(("L1" 60 2) ("L2" 320 4) ("L3" 170 9)))
I have something that takes block attributes and outputs the answer to a table. Is that your next post ? Please continue in 1 post.
Can you post a sample dwg ?
