Moving objects a distance based on dimscale
scottPBYAJ
Observer Observer
scottPBYAJ
Observer
Observer
Hello to you wonderful people. I have been dabbling with LISP and would like to know what is the correct routine for the following,
I want to simple move the previously selected objects direct up a distance equal to dimscale x8
(defun c:MJ () (COMMAND "MOVE" "P" "" 0,0  0,(* 8 (getvar "dimscale"))) (princ) ;suppresses nil return )
The problem is it stops the command after getvar.
Your help is greatly appreciated
Kent1Cooper
You're mixing AutoLisp list format and keyboard-entry format.  Comma-separated coordinates are keyboard entry format, and can't include an AutoLisp expression directly.  Try this:
(defun c:MJ () (COMMAND "MOVE" "P" "" '(0 0) (list 0 (* 8 (getvar "dimscale"))))
No comma between the coordinates in a list, including between the bold-italic zero and AutoLisp function.  You could also use "0,0" [with the comma but in quotes, as a text string as you would type in] for the start point.
Kent Cooper, AIA
scottPBYAJ
Observer
Observer
Thank you Kent works as intended. I'll need to do some more research on the '
Kent1Cooper
@scottPBYAJ wrote:
.... I'll need to do some more research on the '
On that subject, you should read in the AutoLisp Reference about both the (list) and (quote) functions, which are kind of inter-related in relation to that.
Kent Cooper, AIA
