Hello everyone,
I am filling out block forms for inventory and on occasion the block that we use has to be altered into a new block. The only issue is that when the block is changed, all the information in the original block is out of order with the new one. I am trying to create a lisp that will move my text to the appropriate areas, based on the changes I made to the block. To make things easier there are two constants: One original block, and one new block that is identical in every way except the labeling, so the dimensions and spacing of the block are the same, just not the name fields.
Attached are some examples, as well as the order in which I would like to translate my text to.
In summary, I would like help creating a lisp that will automatically move numbers in the order of the first block, to make the numbers in the second block to go with their correct field after rearranging it.
