Lisp to create table from cumulative value of attribute of selected objects
cool.stuff
Message 1 of 9
cool.stuff
Hi!!!
Is there a lisp to create a table from selected objects and return the cumulative values of the defined attribute (e.g. visibility) of them?
For instance, I run the lisp and it asks to select the objects (blocks) and then I select 50 different lines with different visibility attributes between them (some have the same visibility attribute, others dont), it sums all lines with the same visibility attribute and generates a table from it.
I couldn't find anything in the forum, but it may exist. 🙂
Many thanks in advance!! 🙂
Replies (8)
Message 2 of 9
pbejse
@cool.stuff wrote:
Hi!!!
Theres tons of program in this forum that creates a table for selected objects. BUT it also depends on source and how its structured.
Important thing is to give more information, dont make us guess how the table would look like, what are selected objects.
Sample drawing would be the best info you can provide to enable us to help you.
Message 3 of 9
Moshe-A
@cool.stuff  hi,
what do you mean by that?
are talking about Cumulative distance of lines? Cumulative attribute values?
post a sample dwg
moshe
Message 4 of 9
cool.stuff
Hi!!
Thanks for the answer!!
I've attached and example.
There are two blocks with different visibility states.
ALso, I've attached an image with an example of required table:
- In the first column the visibility name;
- In the second colmun the number of blocks/objects with the same visibility;
- In the third column, the cumulative length of block line;
Many thanks!!!
Message 5 of 9
cool.stuff
Hi!!
Many thanks!!!
Message 6 of 9
Moshe-A
@cool.stuff ,
1. there is only 1 block that contains 2 parts (left and right) but it is still 1 block.
2. what does this block\figures represent in real world?
moshe
Message 7 of 9
cool.stuff
Hi!
It represents some architectural elements, for which I need to measure the perimeter.
Many thanks for your help
Message 8 of 9
pbejse
Where is the source for the length?  Is it the value of 'user1" or  'user2" from "flip chain" block? Distance between two blocks of the same visibility with a connecting "line"?
Message 9 of 9
pbejse
I'm guessing the questions we threw back  at @cool.stuffis as confusing as the original request, either that the OP ended up with posting the same request on some other forum and got good results.
I'm sending out my spider bot to find out.[ seek boy ]
webbot.png must find, must find same posts...
