Move anonymous block insertion
john.uhden
Mentor Mentor
Message 1 of 15
john.uhden
I can build an anonymous ("`*U*") block,
and I can entmakex an insertion named 'e' at (setq p0 '(0 0 0))
but when I try to (vl-cmdf "_.move" e "" p0 pause) within the code, AutoCAD crashes.
I can (vl-cmdf "_.move" e "" p0 pause)  after the code (without the move) has finished.
Osmode is 0.
The objects within the block are only lines, text, and one lwpolyline.  No reactors.  No locked layers.
What trick am I missing (gc, regen, vla-update, (setvar "please_behave" 1))?
Should I try using (entlast) instead?
Might my problem be using ACAD2002?
John F. Uhden
Replies (14)
Message 2 of 15
Sea-Haven
Why insert block/entmake then move why not ask for correct point use that in insert block/entmake ? Not sure what your trying to do.
In a pop menu ^c^cINSERT ca3ch-1 DRAG \1;;DRAG
Message 3 of 15
komondormrex
i am fairly doubtful you can build an anonymous block:
asterisk IS USED by the operating system.
thence after a "building" of an anonymous block you've crashed autocad.
imo.
Message 4 of 15
john.uhden
@komondormrex ,
Entmaking an anonymous block is not a problem.  I've been doing it for decades.
It's the MOVE command that prevents AutoCAD from continuing.
But @Sea-Haven has the answer, I think... Include the positioning with the insertion.
I suppose I could use a (while (not done)(gread ...)) approach to keep changing its insertion point, but I don't think grread obeys any object snaps, the way that MOVE does, not that it should matter, but you must always think about what the user might want.
For you curious lurkers of all levels, one thing I just learned is that once you start entmaking a block definition you must entmake all its parts.  Including a vla-add will make an object, but it won't become part of the block definition.
John F. Uhden
Message 5 of 15
john.uhden
@Sea-Haven ,
So much for that idea.  Apparently the INSERT (nor -INSERT) command does not accept anonymous block names, even with the "`" prefix, as in "`*U1."   "Invalid block name."
And I certainly don't want to create a named block.
Unless there's another way, grread here we come.
John F. Uhden
Message 6 of 15
Moshe-A
@john.uhden hi,
i do not see any problem (i am on R2022) check mine 😀
(defun c:test ()
 (entmake (list '(0 . "BLOCK") '(70 . 1) '(2 . "*Uxxx") '(8 . "0")  '(10 0.0 0.0 0.0)))
 (entmake (list '(0 . "circle") '(8 . "0") '(10 5.0 5.0 0.0) '(40 . 1.0)))
 (setq bname (entmake (list '(0 . "ENDBLK"))))
 (setq ent (entmakex (list '(0 . "INSERT") '(8 . "0") (cons '2 bname) (setq p0 (list 10 0.0 0.0 0.0)) '(41 . 1.0) '(42 . 1.0) '(43 . 1.0) '(50 . 0.0))))
 (command "._move" ent "" (cdr p0) pause)
Message 7 of 15
ec-cad
Crash may be caused by lack of a Block Definition in the Block Table ?
Once you entmake that block 'insert', try moving entlast..
ECCAD
Message 8 of 15
ec-cad
You say: "I can entmakex an insertion named 'e' at (setq p0 '(0 0 0))
but when I try to (vl-cmdf "_.move" e "" p0 pause) within the code, AutoCAD crashes."
'e' would be a Blockname ?.. if so, you would need to select it as an entity or object I would
think, in order to "_.move" e ......... if e = a selection set, entity, then fine.
ECCAD
Message 9 of 15
john.uhden
@Moshe-A ,
You are always so helpful.
That's great news but, alas, I can test on only ACAD2002. 😖
John F. Uhden
Message 10 of 15
john.uhden
@ec-cad ,
E is the symbol name for the insert entity.
John F. Uhden
Message 11 of 15
john.uhden
@ec-cad ,
(entlast) was the trick.  YAY!!
John F. Uhden
Message 12 of 15
Moshe-A
@john.uhden ,
thanks John,
The code is for R2002. btw on what platform (OS) you are running 2002?
you did not post your code maybe when insert the block your where using (entmake) instead of (entmakex)?
Moshe
Message 13 of 15
john.uhden
Hi, @Moshe-A ,
OS is Win10.
I almost always prefer using entmakex because it returns the entity name, as in
(setq e (entmakex ...))
But my AutoCAD could not continue when I tried to "MOVE" e.
I know I had tested (outside the program, leaving e as global) with (entget e) and all looked fine.
Maybe it was a timing issue, but entlast saved the day.  Who woulda thunk? (other than @ec-cad )
John F. Uhden
Message 14 of 15
Moshe-A
@john.uhden ,
It's medical miracle that R2002 works under windows 10, i thought it is crashing on each step?!
Moshe
Message 15 of 15
john.uhden
@Moshe-A ,
It sort of IS a miracle.  I found that I had to use the LongBow installer.  Great people.
John F. Uhden
