This may be useful pick a dynamic block as well as a normal block part of another program, please not tested for this task.
(defun c:wow ( / )
(princ "\n Pick 1 block object for block name ")
(setq ss (ssget "+E:S" '((0 . "INSERT"))))
(if (= ss nil)
(alert "You may not have picked a block please try again")
(progn
(setq blk (vlax-ename->vla-object (ssname ss 0)))
(setq bname (vla-get-name blk))
(if (wcmatch bname "*U#*")
(setq bname (vla-get-effectivename blk))
(princ "\nSelect the blocks ")
(setq ss (ssget '((0 . "INSERT"))))
(if (= ss nil)
(alert "No blocks picked will exit")
(progn
(setq lst '())
(repeat (setq x (sslength ss))
(setq lst2 '())
(setq blk (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
(setq blkname (vla-get-name blk))
(if (wcmatch blkname "*U#*")
(setq blkname (vla-get-effectivename blk))
(if (= blkname bname)
(progn
(setq atts (vlax-invoke blk 'Getattributes))
(if (= atts nil)
(princ "No Atts")
(progn
(foreach att atts
(setq lst2 (cons (vla-get-textstring att) lst2))
(setq lst (cons lst2 lst))
(princ)
