Modifying a blocks Custom Drawing Properties
SORONW
SORONW
In preparation for an impending upgrade, we have had to develop a new title block block. This new block makes use of an external PLM software to control 'most' fields through a number of custom drawing properties. The problem is that when inserting the block into a new drawing, there doesn't appear to be a way to modify the few remaining fields through a Lisp Routine.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/vla-addcustominfo-function/td-p/1471...
(defun PutCustomInfo (ID Value Index / Info Num)
	(and
		(vl-load-com)
		(or *acad* (setq *acad* (vlax-get-acad-object)))
		(or *doc* (setq *doc* (vlax-get *acad* 'ActiveDocument)))
		(vlax-property-available-p *doc* 'SummaryInfo)
		(setq Info (vlax-get *doc* 'SummaryInfo))
		(setq Num (vla-NumCustomInfo Info))
		(setq Index (max Index 0))
		(if (> Index Num)
			(not (vla-AddCustomInfo Info ID Value))
			(not (vla-SetCustomByIndex Info Index ID Value))
		);if
	);and
);defun
(PutCustomInfo "scale" ps 0 )
I can use the above code to modify the custom property directly in the titleblock .dwg, but not when inserted into another drawings.
Any suggestions?
Moshe-A
@SORONW  hi,
just a thought 😀 what about linking the block reference (your title) to the dwg using hyperlink?
maybe attaching the custom fields from dwgprops using xdata?
Moshe
