Modify Visibility state change program for selected blocks
murmanator
murmanator
The program below works great to modify ALL blocks in model space to the defined visibility state. I would like to modify it to change only selected blocks.
(defun c:changevis ( / blk idx obj sel vis ) ;;;<<< CHANGES VISIBILITY STATE OF ALL BLOCKS IN MODEL SPACE
(setq blk "SCHEM-SPA-RTN" ;; Block Name
vis "90" ;; New Visibility State
(if (setq sel (ssget "_X" (list '(0 . "INSERT") (cons 2 (strcat "`*U*," blk)))))
(repeat (setq idx (sslength sel))
(if (= (strcase blk) (strcase (LM:blockname (setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))))))
(LM:SetVisibilityState obj vis)
(princ)
I tried a few ways of using this but nothing worked out (this is a program I use to change the Block Table selection, I thought it would work for Visibility state also but no):
(defun C:TEST ( / ss )
(if (setq ss (ssget '((0 . "INSERT"))))
(while (setq e (ssname ss 0))
(setpropertyvalue e
"AcDbDynBlockPropertyVisibility 1" 90)
(ssdel e ss)
)(princ)
CodeDing
@murmanator ,
Just remove this piece and it will force the user to select items instead:
murmanator
Thanks @CodeDing , I tried this and it returned ; error: bad argument type: lselsetp nil
(princ)
CodeDing
@murmanator ,
I did not mean for the entire line to be deleted. Only remove this part:
"_X"
Sorry, I thought my formatting would have made that clear.
murmanator
My apologies, the formatting did not come through in the email, it looked like the whole line. That did do the trick, thank you again!
