Modify Elevation Lisp w/DCL (ModZ)
Jonathan3891
Advisor Advisor
Jonathan3891
While learning DCL I created this lisp & DCL.
It allows you to modify the elevation. It gives you the ability to select objects or modify everything.
I searched to see if anything similar existed but I didnt find anything, so I wanted to share with the community. Maybe you will find it useful
Its based on something I use frequently in MicroStation.
Constructive criticism is welcome!
Jonathan Norton
Blog | Linkedin
john.uhden
I am thrilled to see you mastering the use of AutoLisp with DCL.
Just for some constructive criticism, I wonder about your use of the symbol Elv.  It seems to be a string, but then your SaveVars function converts it into a real, but then since it is local to SaveVars, it is not really saved at all.
Also, since I am a little ignorant, I didn't realize that the Change command can accept a string as a real.  Thank you for demonstrating that.
Now to be really picky, I don't like your use of the symbol name "flag."  I prefer to name the result of (done_dialog) as "action" with "flag' reserved for something like the 70 code for a layer entity.  Hey, whatever with which you are comfortable is really what counts.
Thank you for sharing.
John F. Uhden
paullimapa
Very nicely done.
I would also declare all your variables including the subroutine saveVars local only to be used with this modz function like this:
(defun c:modz (/ dcl_id flag saveVars ss ssi)
 (defun saveVars(/ Elv)
  (setq Elv(distof(get_tile "Elv")))
The next thing to try would be to include in the lisp function a routine to write the dcl file on the fly to the temp folder location (getenv"temp").  Then have a routine to load the dcl from this temp folder location and after the routine is complete, delete the dcl file.
Keep at it.....you're doing really well.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
