Could you please write a lisp to modify block attributes for Multiple blocks, the requirements are below,
1. Block names are BCH-X-BORD-DXXX, BCH-X-BORD-BXXX, BCH-X-BORD-AXXX, BCH-X-BORD-REVI,
2. attribute_tag "REV_`#, R_NO_D&E", change attribute from 1A to 1B or to 1 "
3. attribute_tag "REV_NO", change attribute from ABC to XYZ
Thank you very much in advance 🙂
The first one solved that problem. There are several blocks in the lisp, this time is different.
The second one works well, but it used three lisps. One lisp called another one. Is it possible to use only one lisp? many thanks.
