mlstyle dialoque box transparent, while mline command
coolkris
coolkris
Dear all,
I need mlstyle dialoque box after I started mline command to set style and scale. Any lisp available please share.
Krish
Accepted solutions (3)
ВeekeeCZ
Only way we could make it 'transparent' is in a fashion that you will start the command with dialog and then, after the setting, you will directly continue in a drawing. Basically we just put MLSTYLE and MLINE commands in a sequence.
You could do that either using a menu macro:
^c^cmlstyle;mline
or LISP
(defun c:MLINES ()
  (command "_.mlstyle" "_.mline")
  (princ)
Only benefit of using a LISP is that LISP allows you do an easy repetition by <enter> or RT click.
coolkris
thanks a lot, whether we can have multiple "mline styles" in single acad.mln etc. or each mlinestyles to be in separate .mln for each mlstyle.
ВeekeeCZ
I have non experience with mline definition, but HELP says this:
Load
Displays the Load Multiline Styles dialog box, in which you can load multiline styles from a specified MLN file.
Save
Saves or copies a multiline style to a multiline library (MLN) file. If you specify an MLN file that already exists, the new style definition is added to the file and existing definitions are not erased.
Sea-Haven
There should be a var for "current mlstyle" same with scale.
CMLJUST          0
CMLSCALE         1"
CMLSTYLE         "STANDARD"
Just make a defun setting vars.
coolkris
Dear all,
Please find attached autocad file, where have multiple mline styles created but to save in single *.lin. only latest .lin is saved.
 Krish
cadffm
*.lin file has nothing to do with the MultiLine-Styles, just with the used linetypes in your style.
If you like to save ML styles, export each style one by one and put the files together,
the file extension is MLN.
Your styles using CENTER and HIDDEN Linetypes, both are standard-linetypes (from acad.lin),
so you don't need to save the linetypes extra.
Just
Command: _MLSTYLE [EXPORT]
and the copy the contents of multiple files to one file.
By hand with Text EDITOR or
[CTRL]+[R] -> CMD
copy D:\*.mln D:\MyFavs.mln
Sebastian
