Minor changes to one existing lisp
mruPRQUJ
Message 1 of 21
mruPRQUJ
I wonder if some minor changes can be added to the below lisp, thank you very much in advance.
1. freeze layer "$X-ANNO-REVC"
2. delete all objects "REVCLOUD"
The lisp is below, it was attached as well,
(vl-load-com)
(defun c:ASet (/ format_date chgtxt adoc data_assoc_list ss attribute_tag attribute_string)
(defun format_date (/ mon date)
(setq mon '("JAN" "FEB" "MAR" "APR" "MAY" "JUN" "JUL" "AUG" "SEP" "OCT" "NOV" "DEC"))
(setq date (rtos (fix (getvar "cdate")) 2 0))
(strcat (substr date 1 4) (nth (1- (atoi (substr date 5 2))) mon) (substr date 7 2))
(defun chgtxt (string)
(cond
(= (car (reverse (vl-string->list string))) 65)
(vl-string-subst "" "A" string)
(= (car (reverse (vl-string->list string))) 97)
(vl-string-subst "" "a" string)
(setq data_assoc_list '(
("DATE" . "2023JUL30")
(if (ssget "_X" (list '(0 . "insert")))
(vlax-for block_reference (vla-get-activeSelectionSet (vla-get-activedocument (vlax-get-acad-object)))
(cond
(wcmatch (strcase (vla-get-effectiveName block_reference)) "BCH-X-BORD-DXXX,BCH-X-BORD-BXXX,BCH-X-BORD-AXXX,BCH-X-BORD-REVI,BCH-X-BORD-REVI-TRIA,BCH-X-ANNO-STMP-OBSO")
(foreach attribute (vlax-invoke block_reference 'getAttributes)
(setq attribute_tag (strcase (vla-get-tagString attribute)))
(setq attribute_string (vla-get-textString attribute))
(cond
(setq item (assoc attribute_tag data_assoc_list))
  (vla-put-textString attribute (format_date))
  (vla-put-textString attribute (cdr item))
(wcmatch attribute_tag "REV_`#,R_NO,R_NO_D&E,R_NO_A&B,REV_NO")
      (cond
       ((wcmatch attribute_string "#[AaAa]")
        (setq attribute_string (substr attribute_string 1 1)) ; keep only #
        (vla-put-textString attribute attribute_string)
       ((wcmatch attribute_string "##[AaAa]")
        (setq attribute_string (substr attribute_string 1 2))  ; keep only ##
      ) ; cond
(= "BCH-ST-DYN-DWG-ISSUE" (vla-get-effectivename block_reference))
(setpropertyvalue (vlax-vla-object->ename block_reference) "AcDbDynBlockPropertyVisibility" "IFC - ISSUE FOR CONSTRUCTION")
t
(vlax-release-object block_reference)
(princ)
Replies (20)
Message 21 of 21
mruPRQUJ
Thank you very much all of you!   🙂
