Minimum (single axis) distance between two 2D polylines
Dalephilip93
Message 1 of 25
Dalephilip93
Hey everyone, I'm looking for a function to get the minimum distance between two polylines on a single axis (Y-axis in this case).
Does anyone have a suggestion on how to create a LISP for this?
The function would produce a line that indicates the location where the two lines are closest on the Y-Axis. It's not difficult to do this manually but need to automate it as I need to do it frequently.
Example:
The function produces the white line automatically between the red & blue line below
Thanks for any help.
Replies (24)
Message 21 of 25
komondormrex
hey,
you are seemingly more in need than the op is)
here you go)
;	komondormrex, apr 2023
(defun arc_segment_center (bulge start_point end_point / arc_segment_direction half_included_angle
														 center_position center_distance arc_segment_center
	(setq arc_segment_direction (/ bulge (abs bulge))
		  half_included_angle (* 2.0 (atan (abs bulge)))
		  center_position (cond
									(< pi (* 2.0 half_included_angle))
										(setq center_distance (/ (* 0.5 (distance start_point end_point))
																 (/ (sin (- pi half_included_angle))
																 	(cos (- pi half_included_angle))
										-1.0			;	center point inside arc
									(> pi (* 2.0 half_included_angle))
																 (/ (sin half_included_angle)
																 	(cos half_included_angle)
										+1.0            ;	center point outside arc
									t
										(setq center_distance 0.0)
										 0.0            ;	center point halfway from arc start poit to arc end point
		  arc_segment_center (polar (polar start_point (angle start_point end_point) (* 0.5 (distance start_point end_point)))
		  							(+ (angle start_point end_point) (* arc_segment_direction center_position 0.5 pi))
									center_distance
(defun get_pline_arc_x_center_list (pline_object / center_x_list bulge_index)
	(setq bulge_index -1)
	(repeat (fix (vlax-curve-getendparam pline_object))
		(if (not (zerop (setq bulge (vla-getbulge pline_object (setq bulge_index (1+ bulge_index))))))
				(setq center_x_list (append center_x_list
											(list (car (arc_segment_center bulge
																	(trans (vlax-curve-getpointatparam pline_object bulge_index) 0 1)
																	(trans (vlax-curve-getpointatparam pline_object (1+ bulge_index)) 0 1)
	center_x_list
(defun get_y_fartherst_intersection (probe curve_object / raw_intersection_point_list intersection_point_list )
	(if (< 3 (length (setq raw_intersection_point_list (vlax-invoke probe 'intersectwith curve_object acextendnone))))
			(progn
				(repeat (/ (length raw_intersection_point_list) 3)
					(setq intersection_point_list (append intersection_point_list (list (list (car raw_intersection_point_list)
																							  (cadr raw_intersection_point_list)
																							  (caddr raw_intersection_point_list)
						  raw_intersection_point_list (cdddr raw_intersection_point_list)
				(car (vl-sort intersection_point_list '(lambda (point_1 point_2) (> (cadr point_1) (cadr point_2)))))
(defun c:Y_most_proximity ( / 1st_curve_object 2nd_curve_object y_list min_Y max_Y min_proximity probe_line_object both_curves_x_list
            probe_intersection_1 probe_intersection_2 probe_proximity proximity_point_1 proximity_point_2
	(setq 1st_curve_object (vlax-ename->vla-object (setq 1st_curve_ename (car (entsel "\nPick 1st pline: "))))
	      2nd_curve_object (vlax-ename->vla-object (setq 2nd_curve_ename (car (entsel "\nPick 2nd pline: "))))
    (vla-getboundingbox 1st_curve_object 'llc 'ruc)
    (setq y_list (list (cadr (vlax-safearray->list llc)) (cadr (vlax-safearray->list ruc))))
    (vla-getboundingbox 2nd_curve_object 'llc 'ruc)
    (setq y_list (append y_list (list (cadr (vlax-safearray->list llc)) (cadr (vlax-safearray->list ruc))))
          min_Y (- (apply 'min y_list) 5)
          max_Y (+ (apply 'max y_list) 5)
		  min_proximity (- (apply 'max y_list) (apply 'min y_list))
		  probe_line_object (vla-addline (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
                  						 (vlax-3d-point (list 0 min_Y))
                  						 (vlax-3d-point (list 0 max_Y))
          both_curves_x_list (append (mapcar 'cadr (vl-remove-if '(lambda (group) (/= 10 (car group))) (entget 1st_curve_ename)))
                  					 (mapcar 'cadr (vl-remove-if '(lambda (group) (/= 10 (car group))) (entget 2nd_curve_ename)))
									 (get_pline_arc_x_center_list 1st_curve_object)
									 (get_pline_arc_x_center_list 2nd_curve_object)
    (foreach x both_curves_x_list
		(vla-move probe_line_object (vla-get-startpoint probe_line_object) (vlax-3d-point (list x min_Y)))
      	(if (and (setq probe_intersection_1 (get_y_fartherst_intersection probe_line_object 1st_curve_object))
       			 (setq probe_intersection_2 (get_y_fartherst_intersection probe_line_object 2nd_curve_object))
      			(if (> min_proximity (setq probe_proximity (distance probe_intersection_1 probe_intersection_2)))
        		    (setq min_proximity probe_proximity
        		      	  x_proximity x
        		      	  proximity_point_1 probe_intersection_1
        		      	  proximity_point_2 probe_intersection_2
    (vla-put-startpoint probe_line_object (vlax-3d-point proximity_point_1))
    (vla-put-endpoint probe_line_object (vlax-3d-point proximity_point_2))
    (princ)
Message 22 of 25
hosneyalaa
@komondormrex
Cool code
He works as required
Message 23 of 25
komondormrex
however if both plines have arc segments in their most proximity the code will miss it.
Message 24 of 25
komondormrex
and otherwise too
Message 25 of 25
Kent1Cooper
@JoseMandirigma wrote:
this isn't mine, I just found this somewhere I forgot and I works for me.
[It does the minimum distance in any direction, not the vertical-only distance.]
Kent Cooper, AIA
