Migrating from version 2017 of autocad to 2014 version
I see that is possible migrating from oldest versions to new and i want to say if it's possible do the opposite action, tanks.
devitg
Choose the SAVEAS to 2014 from 2017
Moshe-A
@Anonymous  hi,
AutoCAD releases 2010 up to 2012 shares the same 2010 database format.
AutoCAD releases 2013 up to 2017 shares the same 2013 database format.
AutoCAD releases 2018 up to 2020 shares the same 2018 database format.
moshe
dgorsman
@Anonymous - please define "migrate"?  Open vanilla DWG files?  Vertical product DWG files?  This is the customization section... do you mean CUIx files?  LISP?  Something else?
scot-65
The only problem I have experienced is with the CUIX.
If there is a newer enterprise or main menu as the source
and wish to use in the older version destination, one can
try transferring thru the CUI --> Transfer tab while in the
older version. It may be stubborn, but it just *might* load.
This would have been my next step to try, but gave up
(R2016 to R2014).
As dgorsman stated - what is being migrated?
For DWG - use TrueView if you do not have the newer anymore.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
