mid and end points of lines and arcs
dario_jukica
Message 1 of 30
dario_jukica
Hi.
I have a drawing with multiple lines and arcs.
I need to place a point od every line end and every arc end and every arc mid.
Overkill at the end to delete multiple.
Please help.
Thank you.
Kind regards,
Dario
Replies (29)
Message 21 of 30
dario_jukica
This is your code modified to add a label with a prompt to choose a starting value.
Thoughts?
(vl-load-com)
(defun c:nobiscumv11 (/ s e i a b c p l startnum)
  (setq startnum (getint "\nEnter the starting label number: "))
  (if (setq s (ssget '((0 . "ARC,LINE"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
        a (vlax-curve-getstartpoint e)
        b (vlax-curve-getendpoint e)
        c (if (= "ARC" (cdr (assoc 0 (entget e))))
        (vlax-curve-getpointatdist e (/ (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) 2))))
      (foreach p (list a b c)
    (if (and p (not (vl-remove-if-not '(lambda (x) (equal p x 1e-5)) l)))
      (setq l (cons p l))))))
  (foreach p l
    (setq textstr (strcat "" (itoa startnum)))
    (setq textent (entmakex
                   (list (cons 0 "TEXT")
                         (cons 10 (list (+ (car p) 1.0) (+ (cadr p) 1.0) 0.0))
                         (cons 1 textstr)
                         (cons 40 1.25)
                         (cons 7 "STANDARD")
    (entupd textent)
    (setq startnum (1+ startnum))
    (entmake (list '(0 . "POINT") (cons 10 p))))
  (princ)
Message 22 of 30
ВeekeeCZ
What's your country's standard, do you use a decimal point or comma?
Message 23 of 30
dario_jukica
I use a decimal point.
Message 24 of 30
ВeekeeCZ
Try this then.
(vl-load-com)
(defun c:nobiscumv11 ( / *error* s e i a b c p l f n)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if f (close f))
    (princ))
  (if (and (setq s (ssget '((0 . "ARC,LINE"))))
	   (setq n (1- (cond ((getint "Initial number <1>: ")) (1))))
	   (setq f (open (strcat (getvar 'DWGPREFIX) (vl-string-right-trim ".dwg" (getvar 'DWGNAME)) "-Coord.csv") "w"))
	   (write-line "NAZIV,E(HTRS),N(HTRS),Z" f)								; heading
      (foreach p (list a c b)
  (foreach p l
    (entmake (list '(0 . "TEXT") (cons 10 (mapcar '+ p '(0.2 0.2 0))) '(40 . 1.25) (cons 1 (itoa (setq n (1+ n))))))
    (write-line (strcat (itoa n) "," (rtos (car p) 2 2) "," (rtos (cadr p) 2 2) "," (rtos (caddr p) 2 2)) f))
  (*error* "end")
Message 25 of 30
dario_jukica
Very good.
One final request would be to separate exported values into columns.
Thank you very much.
Message 26 of 30
ВeekeeCZ
Well, that was my previous question about......
(vl-load-com)
    (if f (close f))
    (princ))
	   (write-line "NAZIV;E(HTRS);N(HTRS);Z" f)								; heading
  (foreach p l
    (write-line (strcat (itoa n) ";"
			(vl-string-translate "." "," (rtos (car p) 2 2)) ";"
			(vl-string-translate "." "," (rtos (cadr p) 2 2)) ";"
			(vl-string-translate "." "," (rtos (caddr p) 2 2))) f))
  (*error* "end")
Message 27 of 30
dario_jukica
I would like to keep the point as a decimal point but have the values separated into columns.
Message 28 of 30
ВeekeeCZ
OK. Do whatever you need to do.
Message 29 of 30
dario_jukica
Thank you very much once again, you've helped me a lot.
Cheers
Message 30 of 30
Sea-Haven
Are they always a closed shape if so use bpoly make a new pline and number the vertices will be in sequential order, so long as the shape is closed and no miscloses.
The dwg is a bit to simple as I expect not all shapes will be like the sample, so no code, can you provide a more detailed dwg ? If the dwg is correct say so and easy task to do.
