Message Box while running publish
bdrill
bdrill
Is there a way to automate the "ok" on message boxes that pop up while running publish? I thought it might be an expert level setting but it has no effect. When multiple images are in a drawing it stops at a message box "multiple images inserted" and will not continue until you hit ok. If you are not watching you have no idea your job is not finished but stuck on that box?
Any ideas?
CodeDing
bdrill,
What kind of images? I will help check settings for you. If there is no setting to adjust this, there is no way to automate pressing the button.
An example drawing might be helpful.
Best,
~DD
john.uhden
I wonder if setting NOMUTT to 1 will prevent the box from popping up.  But you had dare not leave it turned on else you will see no communication from AutoCAD.
John F. Uhden
